24-12-2022 10:26 PM
Hi there,
I don’t have the original paperwork with my EE Wi-Fi password, where can I find my password
24-12-2022 10:34 PM
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then, if the WiFi password is not also found under the battery cover, on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
24-12-2022 10:34 PM
