4GEE WiFi Mini - Can you text?
jkingsbury1
Valued Contributor
Valued Contributor
Is there a way through the user interface (192.168.1.1) where you can text from this device? I know that you can receive texts, view them and forward them, but you can't send them if I am correct.
This is a bit problematic when you want to start a new data pack and the message tells you to text 'NOW' to '150' to start the new pack. The only way to activate is to call EE.
jkingsbury1
Valued Contributor
Valued Contributor
Hi, I just found out as per the original query that if you respond to an existing 150 message through the Mini WiFi box you can activate a new package.
Jon_K
Former EE Employee
Hi @jkingsbury1.
You should be able to receive a text, but not send them.
You could try putting your SIM in a phone to send this.
Jon
With that particular mobile router you may not send new texts but only send replies to received texts.
jkingsbury1
Valued Contributor
Valued Contributor
That's a good idea when you already have a received text from 150. It doesn't need to be connected with what you want to say.
