IPv4 only device
mrobz
Hi
I have a medical device which uses 4G to send data to a remote server.  The device doesnt have support for IPv6, only IPv4
I'm using the APN settings everywhere, eesecure and secure
The configuration of the device allows me to add "APN extra commands" - this is the only other config change I can make  -  is there a command I can add in there to set the connection to IPv4 only?
Thank you
PIN
APN name
everywhere
APN port
APN user
eesecure
APN password
secure
APN extra commands
GSM ping server
8.8.8.8
mrobz
PS Should have mentioned - the device currently doesn't connect
It connects fine to most other mobile data networks
@mrobz  You might find what your looking for HERE
mrobz
Hi Chris_B - thanks for replying but that link only listed the APN name and user name/password that I already have
everywhere
eesecure/secure
I think the problem I have is with using IPv4 it seems EE favours IPv6
