26-03-2024 10:21 PM - edited 26-03-2024 10:22 PM
Hey everyone, scratching my head with this one and have been hesitant to contact EE support just because explaining this over the phone may be a challenge. Wanted to get some advice here first hopefully.
I have a 5G unlimited data sim. I've been using it in my Huawei CPE Pro 2 for about 9 months now and it's been fantastic. I went from ~25mbps to ~180 overnight and it's been extremely reliable.
A couple of weeks ago (~15th March) we started noticing pretty bad speed issues. Nothing had changed on the internal network in the last week or so. LAN speeds were fine, so determined it was the EE connection.
Reported issue with coverage to EE on the 17th as it still hadn't resolved, and was told everything was fine in my area.
I've been doing regular speed tests with a docker image on my local network. Note, the x axis is misleading, originally I was testing every hour, and the container stopped at certain periods as I tried resolving the issue by playing around with DNS servers or VPN tunnelling. I switched to 15-min interval testing a couple of days ago (which starts about halfway through the graph). Total of ~116 tests.
TL;DR: The tests showing speeds of ~4mbps all start from 08:00, and stop at around 23:00.
Obviously, I expect fluctuation in data speeds, that's normal. But the consistent <5mbps speed for >12 hours a day is clearly more than a fluctuation.
I've ruled out any changes to our network internally in those times. I do work from home, but I'm more of a night owl so the speeds drop significantly before I'm even on the internet, and if anything my usage increases after 23:00 to make use of the speed boost whilst I have it. So I don't think it's a local bandwidth issue.
What is weird - which prompted me to to write this post, is after taking the sim card out of the router and putting it in my phone, I was getting decent speeds again. As soon as i tethered from my phone to the PC I could barely get 2 mbps download.
I don't think it's an issue with switching between 5G &4G masts, as with the phone test I described I restricted network connection to 4G only (which is what I typically connect to on my Huawei router).
Am I being throttled? I would have thought i'd have been notified by EE if I broke some sort of fair use policy and they were throttling me this much.
on 26-03-2024 11:08 PM
Following due to very similar issue that seems to have started from a very similar date. See post here.
on 26-03-2024 11:12 PM
Very interesting to read this as I've looked back at when my customers reported this. One customer specifically said the issue started on the 15th March! The other customer was less specific but very similar date.
Is this EE or Huawei, I wonder? The company are very secretive about their firmware and that's lots of bad press in previous years that wiped out their phone reputation....
27-03-2024 10:41 AM - edited 27-03-2024 10:45 AM
I would be surprised if this was a Huawei caused issue - just because I have my CPE Pro 2 in bridge mode meaning there's no updates etc. It could be a Huawei specific issue though.
Having said that - it doesn't explain why I was getting good speeds on my Xiaomi 11T Pro, until I attempted to tether which caused it to nose dive to 1 mbps.
Given the very rigid periods of time this affects I feel this must be an EE issue. Although throttling tethered devices is a no-no (I think anyway), it wouldn't surprise me if they had some sort of network prioritisation during peak periods. Could it be possible there's been a bug with that? I know only EE can answer that.
on 27-03-2024 10:48 AM
@AdamInt What part of the country do you work in/serve customers? I'm Norfolk based, so curious if this could be a local issue.
on 27-03-2024 12:06 PM
I am in Cambs, so fairly close by. Would be interested in discussing this directly with you at some point.
One very specific pattern that I am seeing is when I am performing speed tests, only certain devices on the network are experiencing slow connectivity whereas others are reporting higher speeds. The same devices seem to suffer consistently during the bad times, and then speed up again. However, other devices appear to be consistently achieve higher speeds throughout the day.
Having already proven that this pattern is not the Wi-Fi or LAN, this is the part that intrigues me the most, as I have never seen this pattern in the last 8 years of specialising in this area. It's almost like the 4G connection (or the router) is limiting certain devices - whilst others are not being limited. As far as I know, the 4G connection itself is unaware of internal MAC or IP addressing, so it keeps pointing towards Huawei.
I intend to swap the 4G router with a Teltonika next week to see what happens.
Another thought, could this be anything to do with the EE and BT integration...?
on 27-03-2024 12:54 PM
Been struggling with this since the 19/03/2024
Basically since the 19th March, I've had my Download speeds reduced to 1-5Mbps between 8am till 11pm.
I've only had my 5G home broadband for a month and it's been fine up to this point.
Basically I've come to the conclusion that the problem might be that I'm somehow getting throttled during the daytime by the tower because:
At this point, I'm at a loss what to do next because it's becoming near impossible for me and my partner to both WFH in our flat because we can't just work nights due to our work.
We live in a listed building so we cannot get fibre or other fixed line broadband apart from ADSL which is too slow.
At this point I might consider moving to Starlink. Unless there is anything EE can do to sort this. I should be guaranteed 5G speeds through the day too, especially since I've not breached my 600GB Fair use limit at all.
on 27-03-2024 01:02 PM
Hey @acharlwood
I've just posted a similar issue
I'm in the Cambs / Fens area as well and I've noticed it around the same time. It was around the 19th for me.
In my situation I have also tested:
All same result of slow DL speeds during the daytime, but at night (Around 11PM) it is fine, slows down at 8AM again. So I don't think it's a 4G / 5G switching issue. It's that we're likely getting throttled from the tower network. Not sure if many more have experienced this, if it's regional, etc.
on 27-03-2024 01:09 PM
@emeralddude69 Me too. Very interesting and within the same district (it is North Peterborough area for me). There must be something significant relating to the date, as the pattern can't be a coincidence. My started on 15th March and reported by two customers in completely different areas, so different masts.
on 27-03-2024 01:19 PM
Hi All,
The first step would be to report these issues via our network status checker.
If our network team aren't able to find a fault, please escalate the issue with technical support.
