05-03-2024 09:09 AM
I have an iPhone 14 Pro Max, and hotspot works fine with all of my devices.
however, for some reason I cannot hotspot to my recently purchased PS Portal. Please could you advise what if anything I need to do to get this to work as it seems EE have some sort of restrictions in place.
thanks in advance
24-11-2024 10:13 PM
Can I ask what this does, before I install it? It says that traffic can be monitored when I go to install on phone - is this safe or am I leaving my device at risk?
many thanks
25-11-2024 07:21 PM
no idea if solved this but this video has just worked for me on EE. Connected first time.
27-12-2024 09:26 PM
I know this is now an old(ish) thread, but if anybody finds it, I got this working after completing multiple steps. I am in the UK using an iPhone 14 with iOS 18.1.1
I set a static IP for my PS5 on my home router.
I forwarded the following TCP/UDP ports on my home router - 987, 8572 and then the range 9295 to 9308
I then followed the steps in the below video on my PS Portal. The only thing I did that was different to the video was the name of the network (hotspot) I was connecting to and its password (both of which can be found on your iPhone), everything else I did exactly as demonstrated.
https://www.youtube.com/watch?v=7FW0hvzUs5E
I am now able to connect my Portal to my phone's hotspot and have it connect back to my PS5.
27-12-2024 10:05 PM
Hi , I will try tomorrow to see if it will work for me too.... i have a Samsung Galaxy S24 ultra , hopefully it will work...
31-12-2024 04:04 PM
Thank you worked for me!
Thank you was going mad!
18-01-2025 07:06 PM
I’m having same issue did you work yours out please
25-01-2025 01:30 PM
This didnt work for me 😞
25-03-2025 10:28 PM
Hi I know your comment was a long time ago but could you tell me how you got your portal to work on your iPhone hotspot please thanks.
12-10-2025 07:40 PM
I can confirm this works, I’ve tried everything for the last couple of months to get it connected. Thanks dude I appreciate it.
13-10-2025 09:06 AM
