10-11-2023 04:12 PM - edited 10-11-2023 04:20 PM
Not sure what has happened - using Edge, screengrab included. (Same effect in Firefox too!)
10-11-2023 05:18 PM
Hi @354-
Same in Chrome.
10-11-2023 05:52 PM
Which device are you both using, @354- and @Northerner? Just trying to replicate the issue and it's showing OK for me (Edge).
10-11-2023 06:07 PM
@Christopher_G - PC - Windows 10
10-11-2023 06:12 PM
Edge Version 119.0.2151.58 (Official build) (64-bit)
Mozilla Firefox - 119.0.1 (64-bit)
10-11-2023 06:14 PM
@Christopher_G - What device are you using and version of Edge?
10-11-2023 06:24 PM
Thanks @354-
Windows 10 Laptop, looks like I'm on a slightly older version: 118.0.2088.76.
I'll see if I can get this fed back, thanks for sending that information over. 🙂
10-11-2023 06:31 PM
@Christopher_G - From the original screen grab, the chunks of text/info/content is there. But in order to see the content more clearly you have to highlight the text/content, this highlights the text content and is more apparent when selected. It seems like there is some type of layer on top that is making the text less visible?
10-11-2023 06:33 PM
Yeah, those were my thoughts from your screen grab too, @354-
It looks like it would if a pop-up comes up.
10-11-2023 06:39 PM
@Christopher_G - Here's a "highlighted" text screen grab. If you don't highlight the text, the content is barely visible. Hopefully the web team will have eyes on it! 🔧
