Digital Voice issues
JonnyManc
Hi
Recently migrated from another isp for my fttp 500mb with digital Voice.
Fttp is working great, but having issues with maintaining digital Voice.
After a couple of weeks faffing, I got it sorted (registering phone etc) at it was ok, but this week callers can't hear me, nor can I hear them.... The phone rings and there is a dial tone.....
Any ideas guys?
209 REPLIES 209
Brilliant Contributor
@SMJ001 You would be better to say which EE Router that you have, the RJ11 connection if used is only for the DSL side connecting to a OR Master socket or to a ADSL filter dependant on the home original wiring and landline setup.. Nothing else, it is in NO way used for any DV landline/voip connection. Unless you are totally confusing the cable / socket arrangement on the rear of the EE Router!
SMJ001
Of course you are correct, the handset is correctly plugged into the BT 431A socket and the DSL is plugged into the RJ11.
Autocomplete gone wild and a long day trying to get the phone working again. Rebooting the router screws up the smart lights and sockets around the house, each one needing a power off/on cycle to get them all in step again and more to do this time of year with extra sockets for the Xmas lights.
@SMJ001 Sounds like you are in control now, they do try to make it easier but it just does not always work out so!👍
Gelert5
Valued Contributor
Valued Contributor
A 'lot of water-under-the bridge' later, and...
Our 5x DV Handsets connected to our SH32B fell-over (again!) on 4th December.
The usual 'No 'Ringing Tone' on Outgoing Calls, the DV Phones DID ring on Incoming Calls, but again there was no Audio in any / either direction' - etc.
However, I got to speak with an 'EE Guide' who actually seemed to know what he was talking about... (WOW!)
He asked me if we'd ever had a  'SIP Regeneration', and then a little later whether we'd ever had an 'HSS Refresh'.
I'll admit that - at the time - I didn't have a scoobie...
However, another 'long-story-short' and he emailed through this information to me:
And this is what is meant by the 'TLA's' above:
SIP - Session Initiation Protocol:
Telephone voice (DV) traffic is now carried in IP packets.
SIP is the protocol that handles the signalling to set up and tear down IP borne telephone calls.
For example, there is a SIP message that starts the process of setting up a call (SIP INVITE message) and also a series of SIP responses which indicate conditions such as 'Busy', 'Ringing' etc.
At the end of the call, one side or the other will send a SIP BYE message to end the call. The SIP INVITE message, in particular, carries quite a lot of information about things such as destination. (e.g. telephone number).
HSS - Home Subscriber Server:
The Home Subscriber Server (HSS) is a central database that stores information and controls what network services people have access to, including calling features and any apparent issues that arise from these features.
He said: "By scanning the HSS we can identify any issues/discrepancies with features and alert the correct department to get this issue resolved."
After the 'HSS Refresh' he actually found 'an issue with one of the calling features within the voice service on the network'.
But he was unable to 'narrow-down' the 'issue', as this can only be investigated / solved by the 'TMC'.
So he raised a Ticket to have this 'issue' resolved by / on 9th December.
He did give me a VOL055-977********* Fault Reference Number (which, as I know, is an Openreach internal reference number).
AND - he did state that this OR Ref# could be tracked via 'BT.com/faults'.
But, (and trust me - I've tried everything!), it cannot be tracked by the likes of thee and me, sadly....
Anyhoo - our DV is still unreliable (it last fell-over on 21st December). So I've since written a snotty 'Complaints Form' to EE - watch-this-space...
AND - I had to REMONSTRATE with a member of the 'EE Executive Complaints' team - who originally wasn't going to pay us Compo for a 'Total Loss Of Service' back in October - claiming that 'intermittency' doesn't 'count'...
He was rapidly 'corrected' by 'yours truly' as to the 'error of his ways'...
If this latest missive of mine has helped anyone, then I'm pleased.
However, if it's all a bit too 'technical', then I apologise - BUT - to 'defeat the enemy, you need to think like the enemy'...
(to quote Fernando Alonso, paraphrasing 'The Art Of War', back-in-the-day...)
Ciao bene,
Louis.
Well done Louis, excellent work. I experienced exactly the same voice problems, got through 3 replacement EE Smart Hub Pluses, each one locked up after 2 weeks or so. They seem incapable of properly testing the product in lab conditions to bottom out the internal software problems. Exec complaints ended up sending me a latest version of the BT Smart Hub 2 which has been happily running now for over a month. I got £60 compensation which didn't impress me given the time this has been going on.
Regards,
Baz
Gelert5
Valued Contributor
Valued Contributor
At ~0400hrs this morning, I awoke to the Bedroom WiFi Disc flashing 'Orange'.
When I went to inspect the 'Technical Log' later at ~1230hrs, I found the Smart Hub Manager Webpage looking slightly different(!) and discovered that the Smart Hub's Firmware and GUI had been updated at ~0327hrs this morning (10th January).
OLD Firmware:     r1.35.0 -R-1138091-PROD-83002            OLD GUI:   1.13.1
NEW Firmware:   r2.68.12-R-1270837-PROD-83002          NEW GUI: 2.36.4
All of our LAN Device (Re)Names are still as they should be.
The 'Contacts.vcf' file was / still is installed.
And the DV Landline also still works(!) when I tested it this lunchtime.
So maybe this new Firmware contains a / the DV 'fix' that has been mooted by EE for a while...?  🤔 🤞🤞
FYI: amongst the other changes rolled-out in this new Firmware, there also seems to be provision for Dynamic DNS, if you're so inclined... 😎
HTH?
Louis.
@Bazos Can you say if you have time how your BT Smarthub2 has been going on the DV system to date. Had OP and user @Midnight_Voice thinking EE Smarthub+ may be the way to go, kind of rocked his boat and said stay away at present, at least the mention now get's him to see and read this extremely long post if he so cares to do.
BT Smart Hub2 has been working normally for about a month now, digital voice working perfectly no lockups or resets!
@Bazos Thanks for getting back and letting the Forum know, long may it continue.. 👍
pst99
Valued Contributor
Valued Contributor
Hi all, just a note to say I got the new firmware this morning...r2.68.12-R-1270837-PROD-83002 with GUI update 2.36.4
I'll keep tabs on my digital voice and feed back if it appears to have cured the issues over the coming weeks...
