05-08-2025 10:24 AM
05-08-2025 12:10 PM
Hi @GR54ANR
Do you have more than one landline in your home? If you do, do any other the other landlines ring?
Does your landline phone have a volume setting on it?
Chris S
07-08-2025 04:29 PM
07-08-2025 04:47 PM - edited 07-08-2025 04:57 PM
Thanks for coming back to us @GR54ANR
Glad this is now working for you.
The delay you get when calling the landline from your mobile, do you hear ringing from the mobile before the landline phone makes a sound?
Have you tried the steps in the Fix common home phone faults and the Unable to Make or Take Calls with Digital Home Phone page? The troubleshooting may help with the delay in ringing.
Speak soon 🙂
08-08-2025 03:41 PM
08-08-2025 06:11 PM
Thanks for getting back to us @GR54ANR.
I'd recommend getting in touch with our team, who will be able to run through some steps and look into this further. They'll be able to check for anything that may be causing a delay with your incoming calls and help get things sorted.
Debbie
