12-01-2024 02:44 PM
Hi
Recently migrated from another isp for my fttp 500mb with digital Voice.
Fttp is working great, but having issues with maintaining digital Voice.
After a couple of weeks faffing, I got it sorted (registering phone etc) at it was ok, but this week callers can't hear me, nor can I hear them.... The phone rings and there is a dial tone.....
Any ideas guys?
05-12-2024 02:33 PM
Typically, all my squares are SW30A
Another failure from EE who assured my they would work.
Going to push them for Smart Wifi Pro equipment now I think. I'm paying them enough and this has gone on for far too long.
05-12-2024 02:37 PM - edited 05-12-2024 02:39 PM
@PaulStafford70 Also remember and do not listen but the SW30A ONLY work with the +Range of router's the PRO also has it's own smart wireless devices..... Link info below router's and smart wifi. Sorry did not pick up on the squares ref earlier.
https://ee.co.uk/help/broadband/getting-started/setting-up-smart-wifi
05-12-2024 05:23 PM
@JimM11
Cool link to the 'Compare Our Range Of Hubs'
Which has confirmed that EE's latest, er, 'design' of their 'Smart Hub Pro SH40J' is not only aesthetically 'challenging' (IMHO) but it simply wouldn't fit on my shelf = too tall enough...!
So I won't be wandering down that particular route any time soon... 😎
09-12-2024 10:12 PM
All,
I’ve have exactly the same intermittent problem with a Smart Hub Plus & DV or cordless & it’s being like this for 9 months. Today I was informed by EE it’s a ‘firmware’ problem with no solution until Feb 2025. Meanwhile I’m still being charged the full cost.
09-12-2024 10:24 PM
@dmcm34 If you where informed that is the fault at least then something to aim for...
19-12-2024 08:36 PM
Might as well add my woes to the list of users who are victims of this totally inadequate implementation of what should be a standard telecom provision in the mid 2020s.
My FTC worked fine since the days of Demon, then forced to switch to BT and then EE. Data is working but slightly slower, occasional DNS lookup hangs and jitter significantly worse. But hey, that's the way of things, an 'improved' service that often under delivers. However thebig problem is Digital Voice.
My system consists of a Draytek 2762 router connected via ethernet to the EE supplied router, effectively using the EE device as a modem on a IP subnet. A couple of Panasonic 'analogue' phones are connected via the provided EE WiFi to RJ11 converter and on to the EE WiFi network as unfortunately there is no way of setting the EE device to use the more reliable Draytek WiFi . All works well - until it doesn't!! The usual problems, no audio, occasional missing dial tone etc. all the symptoms so many people have stated on this forum.
The big problem is that it is impossible to detect that incoming calls are failing or to know if you are able to make an outgoing call until you go and try when you pick up the handset. I have 2 very elderly relatives who will only use the landline number and get very stressed when they cannot get through - the concept that someone might have a mobile number in addition sometimes fails to be remembered.
The EE suggestion that reseting the router is a fix is wrong and misleading - it is just alleviating the symptom until the next failure. Another 30 minutes is wasted power cycling and rebooting for it to happen all over again in a few weeks (if lucky). Sometimes, you may not have physical access to the EE device to reboot if away from home for instance and consequently miss any answer machine messages etc. when you return.
So where do we go from here? If the service was free it would be something that, maybe, people would put up with. But it isn't free, we are all paying EE for the privilege of using a service that fails to meet the most basic of technical requirements. To be fobbed off by their 'Reboot = Fix = Fault no longer present' mantra is I feel is totally unacceptable.
Time to get off soap box
19-12-2024 08:45 PM
@SMJ001 Lets start off by the following, the DV Landline DOES not use the Wireless Wi-Fi signal in any format what so ever.... Also stated is that the EE DV service for DV is good, and that the EE Smarthub+ router is the complete fault for the whole operation. Only and as yet not fully confirmed that the new EE Pro router has fixed all the DV landline issues.
19-12-2024 11:31 PM
I don't think I said that DV is communicated over the IP infrastructure by wireless and I am aware that the DV Landline is using Voice over IP. There is a however a WiFi connection between the EE/BT Phone Adapter and the EE hub, after all it makes use of WPS for the initial setup. I have also tried taking the adapter out of the equation by connecting a phone straight into the RJ11 at the back of the hub still no joy. Wait to see how long the last reset lasts.
19-12-2024 11:44 PM
Actually, no. Both the Adapter and the Digital Home Phone handsets are connecting to the hub via DECT, not Wi-Fi. Wi-Fi isn't used at all. The WPS button just doubles as a pairing for DECT as well as Wi-Fi. You can even turn Wi-Fi off entirely, and still pair the DECT handsets and adapters.
But yes, to your point, neither is VoIP Wi-Fi though actually it can be, as VoIP is just IP packets… which therefore can use Wi-Fi at any given time. But the handsets and adapter connect to the hub as a base station the same as any cordless DECT handsets do.
20-12-2024 02:03 AM
Thanks for clarifying that, much appreciated.
It would also explain why I couldn't get the adapter to work directly with the Draytek! I should have looked at the frequency spec as 1881-1897 is way below the 2.4GHz for the WiFi.
Ta
