Deco X73 DSL
ned6161
Hi, can someone help please I have replaced my EE smart hub with a Deco X73 as a router. The EE hub would not connect correctly to my current Deco mesh,(no issues on BT broadband) The internet is working fine along with a stable mesh wifi. My problem is I cannot get the phone to work and wonder if anyone has had success using a X73. I am looking for the following information or if it won't work then could someone confirm this is the case. Thanks in advance.
Telephony Provider: Choose your telephony provider. If your telephony provider is not listed here, select Other.
Phone Number: The phone number you use to dial and answer.
Registrar Address: Usually a domain name, if not, an IP address.
Authentication ID and Password: Not necessary information, but if you have, fill them in.
Registrar Port: The port number for the SIP Registrar server.
SIP Proxy: The network address of SIP proxy, which can be an IP address or a domain name.
SIP Proxy Port: The port number of the SIP proxy.
Outbound Proxy: The network address of the outbound proxy, which can be an IP address or a domain name.
Outbound Proxy Port: The port number of outbound proxy.
Register Via Outbound Proxy: Whether to register the telephony account via SIP outbound proxy.
10 REPLIES 10
@andreabunnie Well done, just makes it so much easier and now you will have control over it all, do let the Forum know in a couple month's time how the VOIP service works out as a controlled DV through your Tp-Link, others may wish to follow in your footstep's!
