Cannot receive calls to my landline
jonpearce
Valued Contributor
Valued Contributor
We had Full Fibre installed 2 days ago. Our landline phone can only dial out but anyone calling in gets an unobtainable tone. EE sent a new hub but that's worse! Just get a message with no dial tone and still no incoming calls. Put the original hub back so at least we can make calls. Doesn't solve the problem though. Not impressed with EE.
31 REPLIES 31
@jonpearce : Specify which hubs involved.
jonpearce
Valued Contributor
Valued Contributor
Smart Hub Plus
@jonpearce : But you speak of more than 1 hub. What's the  original hub?
jonpearce
Valued Contributor
Valued Contributor
The same type. The operator we spoke to sent a replacement thinking the original could be faulty. Both hubs Smart Hub Plus
jonpearce
Valued Contributor
Valued Contributor
Tried dialling in from mobile and a friend's landline and also plugged a wired handset in. Still the same. I'll have to call CS back on Monday when I'm in a better frame of mind!
@jonpearce Three parts to the digital voice service as delivered via the EE Smarthub+ Router.
1. The landline is now via the connection on the rear of the Router, all original phone line connection dies.
2. Service is divided into two separate parts, incoming calls and outgoing calls. One may work or start working before the other, ie you may be able to receive but not dial out or in reverse off that condition. After this fact it can take a good 24-48hrs for the transfer old/new to take place and fully function.
3. Services from other landlines, other operators, all the mobile networks etc all have to operate through the EE DV servers and direct to your EE Router. After a couple day's if not working, reset the Router powering it off for five minutes then restarting it. Finally text PHONE to 66033, this will initiate EE to test the DV side off operation, either find a fault or not, but you can expect return text's back and possibly an EE/BT Guide to give you a call, does work on registered mobiles that EE/BT are aware off and if you indeed can send that text! Test the dial out to your mobile, check that caller display and is sending you the correct number you expect to see, sometimes temp number gets assigned by mistake!
jonpearce
Valued Contributor
Valued Contributor
Strange thing..I sent an sms text to the landline from my mobile and the home phone rang and announced the text.
@jonpearce Time to go get the help on the EE DV features hopefully it's getting updated with all the addon's etc that are happening to it!
Leanne_T
Morning @jonpearce
If you've not already contacted our broadband tech guides since you last posted, please get back in touch and the guide will get everything looked into and see what the next steps will be to get this sorted for you.
Please keep us updated with how you get on 🙂
