UNBAR
Winsley94
Apparently I have a third party Block on my account. Although I have UNBAR it. It seems to have but the bar back on
10 REPLIES 10
What makes you say this?
Neeta2001
Were you able to fix this? My number had the bar removed from the beginning and suddenly it started refusing me to use pay by bill and no one can explain it or change it...
Did you sorted it out?
Linzi_H
Hi @Neeta2001
Welcome to the community.
Have you been able to use Charge to Bill services before?
What happens exactly when you try and use this service?
How long ago was the bar removed for you to be able to use this?
Linzi
Hello.
I was using it since I have my number. First with BT, then after they've combined with EE.  Last week I tried to use it after some time and since then I recieveing this message back: "You are unable to use this service; you have a 3rd party bar. To remove the bar text UNBAR to 150"
When I sent the text UNBAR to 150, the reply is that I don't have any bar applied on my number...
I talked with the advisor on the live chat, apparently he also removed any bars possibly applied, and that was 2 days ago but still no change at the moment. I don't have any spend cap, or parental control or anything else. Last month I was using it with no issues
Linzi_H
I wonder if there is a bar hiding within the background of your account that needs to be double checked by our team @Neeta2001
I'd suggest calling us so we can run some further checks for you.
Linzi
Wazzafazza50
Hi can u take the bar of me phone.
Hi have u took ure bar of if so how have done this please.😁
I think it has ended up on call anyways. I tried to sort it out on the  hat but every time they've told me they removed every bar it wasn't working. I don't remember what exactly he said but it was ridiculous anyway. Something he said about me reaching some other limit then official limit... Which for me is ridiculous. If monthly limit is £240 I should be able to use £240 not £100 because of the limit no one knows about or hear about at any time before...
