on 08-02-2025 08:58 AM
Am I entitled to a refund?
on 08-02-2025 09:02 AM
@El_Fergo Is anyone else on EE having this same issue? Have you tried a different sim in your device or your sim in a different device? Does WiFi caking work ? this is an important one to know because if it doesn’t then your sim is probably faulty and you need to request a replacement SIM card.
on 08-02-2025 09:21 AM
No network gurantees 24/7/365 100% uptime in a particular area, but is there a recognised network fault in your locality, showing on the status board? ("Check service status" on https://ee.co.uk/help/mobile-coverage-checker )
on 08-02-2025 09:50 AM
Definitely an issue with the area, it's all anyone can talk about at the minute.
on 08-02-2025 09:51 AM
Yeah there's a known fault and it's taking a lot longer to fix than expected apparently
on 08-02-2025 10:14 AM
FYI you have a short time after posting to edit, negating the need for multiple short replies.
The vast majority of local outages are resolved quite promptly, but sometimes when there are third party issues outside EE's direct control - these are a significant cause when losses of service become protracted. It's never intentional.
You can always use WiFi-calling to continue using your phone indoors anytime there's a coverage issue - whether the reason is lack of coverage, or a fault. EE-CS should be your point-of-contact for all account-specific issues.
on 08-02-2025 10:15 AM
@El_Fergo , if you have broadband and a phone that has wifi calling, then use that, as that will work.
