wifi
gary641
Im looking for the best wifi in my home for around two months.
I use an amazon firestick for IPTV and would like a good wifi signal.
Any ideas on what is the best option please.
Choose from BROADBAND DEALS
18 REPLIES 18
I was told about a MIFI device what is required for this to enable internet in my home?
You could have either:
  1. Fixed Home BROADBAND
  2. Or Mobile Broadband
Mustrum
Hi @gary641 broadband deals tend to be for a minimum of a year, often 18 months, more recently 2 years. So if you only need it for 2 months may be a problem. It can be delivered over a suitable line to your home, or via a mobile service.
MiFii uses a small device plugged typically into a USB port and like Mobile Broadband needs a suitable sim card.
This article on Uswitch helps explain how it works and compares with mobile broadband.
https://www.uswitch.com/broadband/guides/what-is-mifi-mobile-broadband/
It seems someone has marked this thread solved a bit too soon!
@Mustrum : EE, & most others, no longer sell MiFi dongles. Even advertised MiFi dongles are actually mobile WiFi routers. What you & uSwitch call MiFi is to all intents & purposes mobile BB nowadays.
The OP just needs to choose between fixed Home BB & mobile BB w/out muddying the waters.
gary641
looking for advise I will be back in UK for around two months.
Im looking for a good wifi in my house for that time.
I do not want a contract, but just want to pay for the time I will be there.
Any suggestions please?
@gary641 : Nowt's changed! Same advice as last time.
Christopher_G
Hi @gary641
Welcome to the community.
It sounds like Mobile Broadband could be a feasible option. What kind of devices will you be connecting to it?
gary641
Hi Cris basically i just want wifi in my house for that period, I will be using a 4K firestick on my TV for IPTV
