13-05-2022 11:23 PM
I am a Landlord of a building with two flats - Downstairs is Flat1 and Upstairs is Flat 2. One of the rwo tenants of Flat 1 has sent the following message " Our wifi contract has run out,our provider ee has offered us a new contract ,but it requires some small works on the house- a small white box on the outside and a small white box on the inside. This will be a permanent upgrade to the quality of wifi you can get in the flat ,and is due to become standard in all homes. Do we have your permission to install this? In the past some Tenants caused lot of damage when they had broad band with another supplier and they had to pay for the damages . I will be getting my Association's and Lawyer's guidance as well.Can EE Community advise me regarding this subject .
13-05-2022 11:43 PM
It's quite normal & the way things are going with BB. It's a gradual transition from Fibre To The Cabinet (FTTC) to Fibre To The Premises (FTTP), often called Full Fibre, - see How is Fibre to the Premises installed?
The tenant probably does not have to take up the offer yet but probably will in the long run. It will probably be cheaper for the tenant to take the offer.
What does BT Wholesale Broadband Availability Checker's Address Checker estimate for that addy? Post just the whole table and the line above it, blanking out the addy.
14-05-2022 08:41 AM
As the install would be done by Openreach I can assure you that the engineers do a very tidy job.
If any damage is caused by the installers then it would be Openreach who would compensate/remediate.
