14-05-2022 11:12 AM - edited 14-05-2022 12:00 PM
Hi
I got EE for years but in last 2 weeks broadband start lossing conection in chester . It happens randomly but at leat few times a day ,I need to hard restart hub to be able to conect again . I try factory reset ,change filter but still happening . technical support is kinda deaf . I think about switching providers becouse you can't play online games like thta . Anyone got similar problem? Is there is any link for live chat for broadband support?
14-05-2022 11:51 AM
What about your phone line? Is it quiet, dial 17070 option 2.
What do you mean support is deaf? Have you rung them and have you had an engineer out?
14-05-2022 11:55 AM
Hi
Landline is working fine(but I hardlu use it) I text them 2 times in recent week to get support (help) no answer/callback so far , I double check me phone line working fine for others.I look around for email adress to ee to send question but they do not have email adress for broadband problems
Thank You
14-05-2022 12:06 PM
Did you follow the instructions on the Broadband contact us page? There is no email, but you can call.
https://ee.co.uk/contact-ee/technical-support/broadband-landline
14-05-2022 12:13 PM
Hi
Yes I checked basics . Waiting time is crazy if you call from landline ,and still no answer .... text no call back ( but they still charge me premium for text) . I will go to shop ee in me day off , and escalette this from them . In chester I never had problems beffore and use ee for years.. no clue what is going on in last few weeks but I relly can't justife staying with them if problem will be not fixed .
14-05-2022 12:22 PM
14-05-2022 12:25 PM
Shops can't fix BB. They're there to sell mobiles.
Was the Quiet Line Test (1470 17070 Opt 2) silent?
14-05-2022 12:38 PM
80 | 79 | 20 | 19 | 78 | Available | Available | -- |
330 | 50 | -- | Available | -- |
Up to 15 | -- | 13 to 16.5 | Available | Yes |
Up to 15 | Up to 1.5 | 13 to 16.5 | Available | Yes |
Up to 7.5 | -- | 6.5 to 8 | Available | -- |
2 | -- | -- | Available | Yes |
2 | -- | -- | Available | -- |
Up to 15 | -- | 13 to 16.5 | -- | Yes |
Up to 7.5 | -- | 13 to 16.5 | -- | -- |
Up to 2 | -- | 6.5 to 8 | -- | Yes |
80 |
20 |
2022-04-15 |
Available |
Available |
N |
N |
N |
02-05-2022 |
N |
N |
Y |
The exchange is not in a current fibre priority programme
14-05-2022 12:40 PM
Speed Test Result
DOWNLOAD
74.6 Mbps
tbbx1 63.8 Mbps
bursting to 75.3 Mbps
0
50
100
x Single tbbx1 Speed httpx6 Speed
0 0 0
983 62.06
1,980 76.38
2,977 74.73
3,981 75.34
4,976 74.56
5,976 74.56
6,977 74.49
7,978 73.47
8,975 74.95
0 0
1,113 38.95
2,112 73.21
2,398 77.07
2,470 62.84
3,106 55.08
4,110 64.58
5,111 63.82
6,112 59.51
7,109 66.22
8,124 57.06
UPLOAD
0
10
20
x Up
0 0
1 0
2 0
3 0
1,016 0
2,029 17.26
3,014 12.93
4,019 15.69
5,013 17.17
6,016 17.75
7,025 17.35
8,014 17.7
17.3 Mbps
bursting to 17.7 Mbps
Your Latency: 21 ms SSL
14-05-2022 12:43 PM
Firmware updated:Sun Dec 13 01:18:27 2020
Board version:01
DSL uptime:0 Days, 1 Hours, 53 Mins, 4 Secs
Data rate:20.00 Mbps / 80.00 Mbps
Maximum data rate:25.90 Mbps / 94.06 Mbps
Noise margin (up/down):9.6 / 9.9
Line attenuation (up/down):6.2 / 6.3
Signal attenuation (up/down):6.1 / 6.3
Data sent / received:115.2 MB / 3.9 GB
2.4 GHz wireless network name:EE-(range)
2.4 GHz wireless channel:Smart (Channel 11)
5 GHz wireless network name:5Ghz- (speed)
5 GHz wireless channel:Smart (Channel 40)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:Default
