on 07-03-2025 03:40 PM
hi can I purchase my own ee smart hub plus I am on 150 and only got the smart hub
I want wifi 6 can I purchase my own modem smart hub plus to get wifi 6 and it will be a ee smart hub plus
Solved! Go to Solution.
on 07-03-2025 04:09 PM
I wouldn't have thought there was too much to be gained with Wifi 6 when you only get a max of 150mbps.
OK, that's the EE Smart Hub (2023) model no. SH20A. It is replaceable by any EE Smart Hub Plus.
on 07-03-2025 04:10 PM
@PeterryanTake a look on the link, see the pictures and report your router.
on 07-03-2025 05:01 PM
thanks I've had to upgrade to get wifi7 for extra £10 a month thanks for all your help
