Smart Hub Plus + Smart WiFi Plus Question...
ChrisP4GEE
Valued Contributor
Valued Contributor
We switched from BT Halo 1 to EE Broadband this week. Part of the deal was a new EE Smart Hub Plus and Smart WiFi Plus.
I have set both up using the Web interface.
If I go on the Web management page of the router it tells me I have 5 wireless devices & 15 ethernet devices.
This is wrong. At this moment. There is one Raspberry PI & one Synology NAS drive wired to the router. A Sky Q box wired to the Smart WiFi Plus box. Everything else is wireless.
Everything is working so I am not overly bothered. Just curious why it's not listing stuff correctly?
1 ACCEPTED SOLUTION
Community Hero
Community Hero
@ChrisP4GEE Sometimes the designation that EE get's throws the software off a little, the latest FW is a little more accurate.
Latest version for the EE Smarthub+ is below, extender connected devices are at best a question mark.
FW: r2.68.18-R-1303195-PROD-83002 and the gui is at App version 2.36.4. 11/02/2025
10 REPLIES 10
Community Hero
Community Hero
ChrisP4GEE
Valued Contributor
Valued Contributor
On the hub page it says I am running FW 2.68.18. App version 2.36.4.
Everything is working. I can see four wifi entries on phone's wifi analyser app. If I move away from the router it switches to the extender.
It's not a specific hardware issue either. For example two Samsung devices are showing on WiFi. Three others are showing on Ethernet!
I have no need to group devices. Or manage them in regards of parental control etc. So I will just leave it be.
If anyone from EE development team is watching. It would be nice if the hub web interface had all the control of the app. 🙂
@ChrisP4GEE How long have you had the issue for?
ChrisP4GEE
Valued Contributor
Valued Contributor
Switched last Monday (was running my own router on BT). Installed the EE hardware Friday afternoon. The device list has been incorrect since I turned everything on.
My original WiFi I had my own names SSID with 2.4GHz & 5Ghz bands split (5Ghz had "_5G" on the end). EE hardware I changed the SSID to match my current 2.4Ghz SSID. Quite a few my devices are on that band (Ring hardware, smart meter display etc). Any devices using the old "_5G" was then moved over. Phones were aware of both SSID names.
I paired the Smart WiFi Plus hardware using the Ethernet cable provided.
@ChrisP4GEE Post a picture of the main web page, hide or blank part of your SSID's that will show device connection. Use the camera to upload the picture or screen capture. Sample below when i find and attach the link.
(1) Re: Ping Issues - Hub - The EE Community
ChrisP4GEE
Valued Contributor
Valued Contributor
I am on my phone at the moment. I will need to grab those from my PC.
Just a note. All my devices (which are on at the moment) are connected to the Internet. The ones that support it (phones, Sky Q box, Amazon FireStick) speed test shows they are running at my broadband's limit.
The router has four ports used.
Port 1 - PC.
Port 2 - Connected to a 4 port switch. It is connected to another switch in the room next door. All the items are currently turned off. Only item on the first switch which is on is a Raspberry PI (has a static IP).
Port 3 - Synology NAS (has a static IP).
Port 4 - EE Hybrid Hub.
The Router's Web page thinks I have 15, active, Ethernet port based devices.
All the devices are working. It's just the web page is screwed as to their connections.
I'll do the screen shots later...
@ChrisP4GEE If a device wireless is routed in any way via an Ethernet switch then you WILL see it as an Ethernet Network connected item. If it is wireless and connects say direct on the router then will show as wireless.
I have for example powerline ethernet connected, other end of it is satellite box (E)+ Ring Doorbell (W)+ Ring Camera (W)+ 1 IOT devices (W) which is 1 Ethernet 3 Wireless, in the Web manager they are all Ethernet (4) off them as the main connection is via the Powerline Ethernet.
That would be my Port 4 with the 4 Devices attached as per the link.
ChrisP4GEE
Valued Contributor
Valued Contributor
No Powerline modules. I did have before the EE switch over, but they are all unplugged now.
I have Smart Hub Plus (only Ethernet is a PC, Raspberry PI, & NAS Drive).
I have a Smart Wi-Fi Plus (wirelessly connected to the HUB). Its Ethernet port is connected to the Sky Q Box.
I installed the EE app and everything appears correctly on the app. It is only broken on the Smart Hub Plus page. So the wireless devices are listed as wireless and connected either to the Smart Hub Plus or Smart Wi-Fi Plus.
Not that bothered. I'll just use the app and ignore the routers own page for now.
Thanks anyway.
Personally, I wouldn't!
