internet drops out every few minutes for a couple seconds.
reiayanami
I've recently installed the broadband hub and I assumed it was just up to it settling and it'll eventually go away but over the past few hours it keeps getting worse and worse, the WiFi is fine then immediately cuts out for a few seconds and comes back, it wouldn't be such a big deal if it didn't just stop me dead in my tracks when attempting to play games or call friends. does anyone else have this issue or is it a common issue for people who have just set up the broadband hub
not sure if its BB or just wifi but we dont have any devices connected to ethernet, only WIFI and this happens somewhat inconsistently but is still occurring enough to be a serious issue, any calls, games, downloads etc just cease to work for a few seconds? maybe a faulty hub? the colors stay the same just on the basic aqua.
Product code:
SH31B
Serial number:
+114403+2317000496
Firmware version:
r1.19.1-R-898041-PROD-83002
Firmware updated:
N/A
GUI version:
1.8.0
DSL uptime:
2 Mins
Data rate:
19.59 Mbps / 72.73 Mbps
Data sent / received:
6.07 MB Uploaded / 13.02 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
Wi-Fi:
N/A
2.4 GHz wireless network name:
EE-9HK85Z
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
EE-9HK85Z
5 GHz wireless channel:
Smart (Channel 100)
Wireless security:
WPA2-Personal
Wireless mode:
Wi-Fi 6 performance
Firewall:
On
The DSL uptime of 2 minutes suggests that the actual broadband link is dropping out, unless your screen grab was taken shortly after restarting the hub?
