on 21-06-2024 03:32 AM
i have tried everything but cant fix it.
i use a wifi adapter usb and i just switched to ee before i was on virgin and it worked fine but now it lags every 35 seconds
Solved! Go to Solution.
on 23-06-2024 01:18 AM
i have finally figured out the problem and feel very stupid now
all i had to do was get closer to the wifi which i did not think would work but it did
ethernet works too
on 21-06-2024 03:33 AM
Which router do you have?
on 21-06-2024 03:37 AM
i have the Smart Hub SH31B
on 21-06-2024 03:42 AM
It's quite normal for pings to time out occasionally when the target is doing other more important things.
on 21-06-2024 03:46 AM
thank you for replying but it does not stop it will always time out every 35 seconds and pause as example when im playing a game it will pause my game for 4 seconds and keep doing that every 35 seconds so it is rlly annoying
is there no way to fix it?
on 21-06-2024 06:55 AM
@SRy0men An OP posted recently that he had logged into the router and set the wireless mode to wi-fi 5 and that fixed his gamming mode, card on the rear of the router for the details you need. Give it a try if you want.
on 21-06-2024 11:07 AM
this sort of did fix it however once i turn my pc off or restart it in anyway the problem comes back sometimes if i uninstall my wifi adapter usb it will work until i turn off or reset my pc
on 21-06-2024 03:39 PM
@SRy0men Have you re checked that the router settings are still good, hit save after changing the option.
on 22-06-2024 12:27 AM
This is everything i have tried i may have missed some things out this is just a summary.
on 22-06-2024 08:11 AM
@SRy0men ? What is it that your are trying to achieve with your testing!
