on 21-06-2024 03:32 AM
i have tried everything but cant fix it.
i use a wifi adapter usb and i just switched to ee before i was on virgin and it worked fine but now it lags every 35 seconds
Solved! Go to Solution.
on 22-06-2024 07:04 PM
im trying to find out why i am getting the request time out ping because it is causing my wifi to pause and makes me lag alot
on 22-06-2024 07:18 PM
@SRy0men What other wireless devices are on the network at the same time? I have pinged for 5000 counts with nothing higher than 150ms in the whole period, and mostly when looking at them 3 to 4 ms with the odd jump but not very sequential, have also pinged google 8.8.8.8 and 8.8.4.4 and never got above 20ms all using wireless. Are you sure it's not an interrupt on your pc that is causing the issue? If gamming and you want to use wi-fi may be try all other devices off if possible.
on 23-06-2024 01:18 AM
i have finally figured out the problem and feel very stupid now
all i had to do was get closer to the wifi which i did not think would work but it did
ethernet works too
on 23-06-2024 06:30 AM
@SRy0men Ethernet should be your first option if you wish to game on the pc, will always be better than wireless. Glad you worked it out.👍
