25-09-2026 09:59 PM
My immediate neighbour on the same line has active FTTP, but my address probably has a database mismatch. I need an advisor to raise an ORDI Address Query with the Connections Team to have Openreach re-survey my UPRN.
25-09-2026 10:07 PM
You'll need to phone CS to request it.
How can your neighbour be on the same line as you?
What does BT Wholesale Broadband Availability Checker > Address Checker estimate for your address? Post the whole table, the text below it and the line above it, blanking out your address.
26-09-2026 12:06 AM
@Nobi1 Do you currently have a broadband supplied connection and if so who is it with?
29-09-2026 08:22 AM
I have broadband with EE, subscribing Fibre 67, which is a traditional ADSL.
29-09-2026 08:23 AM
I should have said “My immediate neighbour on the same street”.
29-09-2026 09:06 AM - edited 29-09-2026 09:14 AM
@Nobi1 No ADSL if you have a Fibre 67, you will be on at least a VDSL connection either FTTC or Sogea.
As EE are supplying you currently then you need to look at why your Home cannot get a FF Full Fibre connection, can be a few reason's as to why not. Post your BTW linked info from below address checker.
See mine linked if you need to post back. Example my Pole has connection for 8 homes, there is also a VM Fibre at the top, currently VM has two neighbours on it, and the OR CBT has 4 homes connected, two still to be done do not expect them to do so and they both currently have a copper connection. The homes 40 in total across the roadway are onto he-haw as OR messed it all up, currently it's a dig civils and they get job by job 2 years later now from OR getting it as said available to all....
Solved: Re: Broadband Renewal Process - Book Installation Slot ?? - The EE Community
