on 17-07-2025 11:25 AM
hi,
just changed from Plusnet to EE and got a new router. I have a cctv camera which connects to the wifi and internet through a wifi extender (it doesn't have a good enough signal to connect direct to the router). It used to work fully through the Plusnet router but now I can only connect to the camera with my phone if the phone is also connected to the wifi extender rather than the router or any other Internet connection, which all worked before.
The wifi extender is connected to the internet, through the router, as my phone connects to the Internet through it. I have enabled the 'wifi compatibilty mode' on the router, for old technologies, and I now can see a new wifi network with my phone. but connecting my camera to that network is a pain because I have to reset it and connect to that compatibility network using a ladder over the roof with no guarantee of success. Any advice please?
on 17-07-2025 05:02 PM
@colin_bryant Program the SSID and password that you have used before to the older settings that the camera had when connecting to the plusnet, set the comp network with those values and the camera will more than likely connect fine!
on 17-07-2025 06:50 PM
@colin_bryant which EE service have you moved to, and are you using Digital Voice?
If not you could use the PN router. if you have not sent it back.
on 18-07-2025 03:13 PM
on 18-07-2025 03:27 PM
18-07-2025 04:53 PM - edited 18-07-2025 05:05 PM
@colin_bryant Have you set up and are you using the compatible network feature off the router in question!
Is it set for 2.4Ghz band only and also operating in the WPA2-PSK for wireless w-fi! Passing through the extender that is closest to the actual camera!
You need to say what EE Router you have, what EE Extenders that you have, and finally what CCTV camera is connecting too it all, camera if you do know, Frequency it use's and wireless security also. Most are 2.4Ghz operation and WPA2-PSK mode in wireless!
on 18-07-2025 05:24 PM
on 18-07-2025 05:36 PM
@colin_bryant if you are going to make us guess and not answer the questions how do you expect to get a fix.
My guess is you are using a EE Smart Hup plus, which is WiFi 6 and which your cameras cannot cope with. The way round this is to set the compatable mode and get yourself up that ladder.
on 18-07-2025 05:49 PM
18-07-2025 05:57 PM - edited 18-07-2025 06:03 PM
@colin_bryant Is there not a matching QR code on the packaging box for the camera, if you have to go up a ladder to get that then it's just stupid way off doing it! Link also about the hubs and the extenders, do take a look, see the pictures and say what you have!
https://ee.co.uk/help/broadband/getting-started/setting-up-smart-wifi
https://ee.co.uk/help/broadband/fix-problem/fix-problems-with-smart-wifi
All about the mode below for you!
Set up and use Compatible WiFi | Broadband Help | EE
