Sony TV not connecting to Wifi
Badah
Just recently upgraded to the new EE super internet.
my tv cannot connect to WiFi (shows as disabled) but is working on all other devices. The tv is also brand new, running android OS.
it was working but now it’s just stopped connecting - extremely frustrating.
14 REPLIES 14
Northerner
Hi @Badah
Have you forgotten the network on your TV and tried again to connect. Have you entered the correct credentials.
David-M
Former EE Employee
Hi @Badah and welcome.
I'd be interested to know how you resolve this so can you try @Northerner advice and let us know?
Cheers
David
Badah
Hi all - I’ve done a factory resent / deleted network on the tv sti the same issue.
Mustrum
@Badah   which model Sony TV do you have, and how far away is the router?
With other devices working, but the TV showing disabled suggests the TV settings may need tweaking.
It’s a sonyxr55a84lu
it was working - I’ve got the mesh system active so there’s both the 2.4 and 5 network. It was working just stopped in the last two days
Mustrum
@Badah   not much to go on there.
It still sounds like a TV setting.
Are you able to use your phone as a Hotspot, and get the TV to connect to that.
Can the TV see the WiFi SSID's ? but not connect - what is happening when you try?
Is the SSID you highlighted meant to be that of your EE Smart Hub Plus? It's showing a BT SSID. EE's start with "EE-".
When I installed my EE hub it cloned all the settings / WiFi name from my previous BT vox
