broadband
ryanmaxwell1996
i have fullfibre broadband 900.
download speeds start at 100mbps and go up to 900mbps then drop slowly back down to 100mbps then back up? its very inconsistent and wondering if there is reason why?
Peter_W
Good morning @ryanmaxwell1996.
Welcome to the EE Community 😊
How is the device you're testing these speeds on connected, ethernet or WiFi?
Also if it's WiFi, do you notice this changing dependent on range, or will it fluctuate regardless of location?
Peter
Try a speedtest, preferably wired using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
