broadband
mskuse3
Hello,
I bought broadband two weeks ago and everything was fine, i just came back after two days of not being home and my broadband is playing up.
My router keeps rebooting or finding connection with the broadband and internet every minute fir the past two hours. It finds a connection and restarts again to find connection.
The power and wireless light are kept on but broadband and internet keep flashing.
I have an EE bright box.
2. What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker, not the Postcode Checker.
