broadband drops out
Boring25
as title says it drops out randomly but more often at night. Why is this happening
Leanne_T
Hi @Boring25
Thanks for coming back to us.
If you give our broadband care team a call on 0800 079 8586 the team will help you get this looked into.
Let us know how you get on 🙂
Leanne,
10 REPLIES 10
@Boring25 : Welcome to EE's Home Broadband Forum.
We don't use ethernet connections, and unsure on the lights on the router when it happens, but speeds are usually very good. BT estimates 40mbps down (unclean) and 13mbps up. Which is in line with what we get consistently.
The router had a huge dropout the other night, here is the log for it. Note that 'sending PADI' continues until around 6am, I can't paste it all because the webpage freezes.
Also had a few DOS attack attempts, these are from this morning:
06:21:51, 18 Jun. Time is synced to NTP server
06:00:52, 18 Jun. Device connected: 192.168.1.74, 10:2b:41:8d:ae:57, Samsung, lease time is 172800 seconds
05:21:34, 18 Jun. Time is synced to NTP server
04:21:18, 18 Jun. Time is synced to NTP server
03:21:02, 18 Jun. Time is synced to NTP server
03:10:30, 18 Jun. Possible DoS attack detected from 64.62.197.168
02:20:45, 18 Jun. Time is synced to NTP server
01:43:35, 18 Jun. Possible DoS attack detected from 89.248.165.103
01:43:25, 18 Jun. Possible DoS attack detected from 89.248.165.103
01:43:15, 18 Jun. Possible DoS attack detected from 89.248.165.103
01:43:05, 18 Jun. Possible DoS attack detected from 89.248.165.103
01:42:55, 18 Jun. Possible DoS attack detected from 89.248.165.103
01:42:45, 18 Jun. Possible DoS attack detected from 89.248.165.103
01:42:35, 18 Jun. Possible DoS attack detected from 89.248.165.103
01:42:24, 18 Jun. Possible DoS attack detected from 89.248.165.103
01:42:14, 18 Jun. Possible DoS attack detected from 89.248.165.103
01:20:29, 18 Jun. Time is synced to NTP server
00:20:12, 18 Jun. Time is synced to NTP server
23:19:56, 17 Jun. Time is synced to NTP server
And this is where there was a complete dropout for several hours
00:26:36, 16 Jun. PPP: Sending PADI
00:26:31, 16 Jun. PPP: Sending PADI
00:26:26, 16 Jun. PPP: Sending PADI
00:26:21, 16 Jun. PPP: Sending PADI
00:26:16, 16 Jun. PPP: Sending PADI
00:26:11, 16 Jun. PPP: Sending PADI
00:26:06, 16 Jun. PPP: Sending PADI
00:26:01, 16 Jun. PPP: Sending PADI
00:25:56, 16 Jun. PPP: Sending PADI
00:25:51, 16 Jun. PPP: Sending PADI
00:25:46, 16 Jun. PPP: Sending PADI
00:25:41, 16 Jun. PPP: Sending PADI
00:25:36, 16 Jun. PPP: Sending PADI
00:25:31, 16 Jun. PPP: Sending PADI
00:25:26, 16 Jun. PPP: Sending PADI
00:25:21, 16 Jun. PPP: Sending PADI
00:25:16, 16 Jun. PPP: Sending PADI
00:25:11, 16 Jun. PPP: Sending PADI
00:25:06, 16 Jun. PPP: Sending PADI
00:25:01, 16 Jun. PPP: Sending PADI
00:24:56, 16 Jun. PPP: Sending PADI
00:24:51, 16 Jun. PPP: Sending PADI
00:24:46, 16 Jun. PPP: Sending PADI
00:24:41, 16 Jun. PPP: Sending PADI
00:24:36, 16 Jun. PPP: Sending PADI
00:24:31, 16 Jun. PPP: Sending PADI
00:24:26, 16 Jun. PPP: Sending PADI
00:24:21, 16 Jun. PPP: Sending PADI
00:24:16, 16 Jun. PPP: Sending PADI
00:24:11, 16 Jun. PPP: Sending PADI
00:24:06, 16 Jun. PPP: Sending PADI
00:24:01, 16 Jun. PPP: Sending PADI
00:23:56, 16 Jun. PPP: Sending PADI
00:23:51, 16 Jun. PPP: Sending PADI
00:23:46, 16 Jun. PPP: Sending PADI
00:23:41, 16 Jun. PPP: Sending PADI
00:23:36, 16 Jun. PPP: Sending PADI
00:23:31, 16 Jun. PPP: Sending PADI
00:23:26, 16 Jun. PPP: Sending PADI
00:23:21, 16 Jun. PPP: Sending PADI
00:23:16, 16 Jun. PPP: Sending PADI
00:23:11, 16 Jun. PPP: Sending PADI
00:23:06, 16 Jun. PPP: Sending PADI
00:23:01, 16 Jun. PPP: Sending PADI
00:22:56, 16 Jun. PPP: Sending PADI
00:22:51, 16 Jun. PPP: Sending PADI
00:22:46, 16 Jun. PPP: Sending PADI
00:22:41, 16 Jun. PPP: Sending PADI
00:22:36, 16 Jun. PPP: Sending PADI
00:22:31, 16 Jun. PPP: Sending PADI
00:22:26, 16 Jun. PPP: Sending PADI
00:22:21, 16 Jun. PPP: Sending PADI
00:22:16, 16 Jun. PPP: Sending PADI
00:22:11, 16 Jun. PPP: Sending PADI
00:22:06, 16 Jun. PPP: Sending PADI
00:22:01, 16 Jun. PPP: Sending PADI
00:21:56, 16 Jun. PPP: Sending PADI
00:21:51, 16 Jun. PPP: Sending PADI
00:21:46, 16 Jun. PPP: Sending PADI
00:21:41, 16 Jun. PPP: Sending PADI
00:21:36, 16 Jun. PPP: Sending PADI
00:21:31, 16 Jun. PPP: Sending PADI
00:21:26, 16 Jun. PPP: Sending PADI
00:21:21, 16 Jun. PPP: Sending PADI
00:21:16, 16 Jun. PPP: Sending PADI
00:21:11, 16 Jun. PPP: Sending PADI
00:21:06, 16 Jun. PPP: Sending PADI
00:21:01, 16 Jun. PPP: Sending PADI
00:20:56, 16 Jun. PPP: Sending PADI
00:20:51, 16 Jun. PPP: Sending PADI
00:20:46, 16 Jun. PPP: Sending PADI
00:20:41, 16 Jun. PPP: Sending PADI
00:20:36, 16 Jun. PPP: Sending PADI
00:20:31, 16 Jun. PPP: Sending PADI
00:20:26, 16 Jun. PPP: Sending PADI
00:20:21, 16 Jun. PPP: Sending PADI
00:20:16, 16 Jun. PPP: Sending PADI
00:20:11, 16 Jun. PPP: Sending PADI
00:20:06, 16 Jun. PPP: Sending PADI
00:20:01, 16 Jun. PPP: Sending PADI
00:19:56, 16 Jun. PPP: Sending PADI
00:19:51, 16 Jun. PPP: Sending PADI
00:19:50, 16 Jun. Device connected: 192.168.1.73, c0:b5:d7:03:9e:55, DESKTOP-FB92O2M, lease time is 172800 seconds
00:19:46, 16 Jun. PPP: Sending PADI
00:19:41, 16 Jun. PPP: Sending PADI
00:19:36, 16 Jun. PPP: Sending PADI
00:19:31, 16 Jun. PPP: Sending PADI
00:19:26, 16 Jun. PPP: Sending PADI
00:19:21, 16 Jun. PPP: Sending PADI
00:19:16, 16 Jun. PPP: Sending PADI
00:19:11, 16 Jun. PPP: Sending PADI
00:19:06, 16 Jun. PPP: Sending PADI
00:19:01, 16 Jun. PPP: Sending PADI
00:18:56, 16 Jun. PPP: Sending PADI
00:18:51, 16 Jun. PPP: Sending PADI
00:18:46, 16 Jun. PPP: Sending PADI
00:18:41, 16 Jun. PPP: Sending PADI
00:18:36, 16 Jun. PPP: Sending PADI
00:18:31, 16 Jun. PPP: Sending PADI
00:18:26, 16 Jun. PPP: Sending PADI
00:18:21, 16 Jun. PPP: Sending PADI
00:18:17, 16 Jun. Device connected: 192.168.1.73, c0:b5:d7:03:9e:55, DESKTOP-FB92O2M, lease time is 172800 seconds
00:18:16, 16 Jun. PPP: Sending PADI
00:18:11, 16 Jun. PPP: Sending PADI
00:18:06, 16 Jun. PPP: Sending PADI
00:18:01, 16 Jun. PPP: Sending PADI
00:17:56, 16 Jun. PPP: Sending PADI
00:17:51, 16 Jun. PPP: Sending PADI
00:17:46, 16 Jun. PPP: Sending PADI
00:17:41, 16 Jun. PPP: Sending PADI
00:17:38, 16 Jun. Device connected: 192.168.1.73, c0:b5:d7:03:9e:55, DESKTOP-FB92O2M, lease time is 172800 seconds
00:17:36, 16 Jun. PPP: Sending PADI
00:17:31, 16 Jun. Device connected: 192.168.1.73, c0:b5:d7:03:9e:55, DESKTOP-FB92O2M, lease time is 172800 seconds
00:17:31, 16 Jun. PPP: Sending PADI
00:17:30, 16 Jun. Device connected: 192.168.1.73, c0:b5:d7:03:9e:55, DESKTOP-FB92O2M, lease time is 172800 seconds
00:17:26, 16 Jun. PPP: Sending PADI
00:17:26, 16 Jun. Device connected: 192.168.1.73, c0:b5:d7:03:9e:55, DESKTOP-FB92O2M, lease time is 172800 seconds
00:17:25, 16 Jun. Device connected: 192.168.1.73, c0:b5:d7:03:9e:55, DESKTOP-FB92O2M, lease time is 172800 seconds
00:17:24, 16 Jun. Device connected: 192.168.1.73, c0:b5:d7:03:9e:55, DESKTOP-FB92O2M, lease time is 172800 seconds
00:17:21, 16 Jun. PPP: Sending PADI
00:17:17, 16 Jun. Device connected: 192.168.1.73, c0:b5:d7:03:9e:55, DESKTOP-FB92O2M, lease time is 172800 seconds
00:17:16, 16 Jun. PPP: Sending PADI
00:17:11, 16 Jun. PPP: Sending PADI
00:17:06, 16 Jun. PPP: Sending PADI
00:17:01, 16 Jun. PPP: Sending PADI
Hi, the speeds are fine when it works.
when the connection drops out it says this:
00:40:52, 16 Jun. PPP: Sending PADI
00:40:47, 16 Jun. PPP: Sending PADI
00:40:42, 16 Jun. PPP: Sending PADI
00:40:37, 16 Jun. PPP: Sending PADI
00:40:32, 16 Jun. PPP: Sending PADI
00:40:27, 16 Jun. PPP: Sending PADI
00:40:22, 16 Jun. PPP: Sending PADI
00:40:17, 16 Jun. PPP: Sending PADI
00:40:12, 16 Jun. PPP: Sending PADI
00:40:07, 16 Jun. PPP: Sending PADI
00:40:02, 16 Jun. PPP: Sending PADI
00:39:57, 16 Jun. PPP: Sending PADI
00:39:52, 16 Jun. PPP: Sending PADI
00:39:47, 16 Jun. PPP: Sending PADI
00:39:42, 16 Jun. PPP: Sending PADI
00:39:37, 16 Jun. PPP: Sending PADI
00:39:32, 16 Jun. PPP: Sending PADI
00:39:27, 16 Jun. PPP: Sending PADI
00:39:22, 16 Jun. PPP: Sending PADI
00:39:17, 16 Jun. PPP: Sending PADI
00:39:12, 16 Jun. PPP: Sending PADI
00:39:07, 16 Jun. PPP: Sending PADI
00:39:02, 16 Jun. PPP: Sending PADI
00:38:57, 16 Jun. PPP: Sending PADI
00:38:52, 16 Jun. PPP: Sending PADI
00:38:47, 16 Jun. PPP: Sending PADI
00:38:42, 16 Jun. PPP: Sending PADI
00:38:37, 16 Jun. PPP: Sending PADI
00:38:32, 16 Jun. PPP: Sending PADI
00:38:27, 16 Jun. PPP: Sending PADI
00:38:22, 16 Jun. PPP: Sending PADI
00:38:17, 16 Jun. PPP: Sending PADI
00:38:12, 16 Jun. PPP: Sending PADI
00:38:07, 16 Jun. PPP: Sending PADI
00:38:02, 16 Jun. PPP: Sending PADI
00:37:57, 16 Jun. PPP: Sending PADI
00:37:52, 16 Jun. PPP: Sending PADI
00:37:47, 16 Jun. PPP: Sending PADI
00:37:42, 16 Jun. PPP: Sending PADI
00:37:37, 16 Jun. PPP: Sending PADI
00:37:32, 16 Jun. PPP: Sending PADI
00:37:27, 16 Jun. PPP: Sending PADI
00:37:22, 16 Jun. PPP: Sending PADI
00:37:17, 16 Jun. PPP: Sending PADI
00:37:12, 16 Jun. PPP: Sending PADI
00:37:07, 16 Jun. PPP: Sending PADI
00:37:02, 16 Jun. PPP: Sending PADI
00:36:57, 16 Jun. PPP: Sending PADI
00:36:52, 16 Jun. PPP: Sending PADI
00:36:47, 16 Jun. PPP: Sending PADI
00:36:42, 16 Jun. PPP: Sending PADI
00:36:37, 16 Jun. PPP: Sending PADI
00:36:32, 16 Jun. PPP: Sending PADI
00:36:27, 16 Jun. PPP: Sending PADI
00:36:22, 16 Jun. PPP: Sending PADI
00:36:17, 16 Jun. PPP: Sending PADI
00:36:12, 16 Jun. PPP: Sending PADI
00:36:07, 16 Jun. PPP: Sending PADI
00:36:02, 16 Jun. PPP: Sending PADI
00:35:57, 16 Jun. PPP: Sending PADI
00:35:52, 16 Jun. PPP: Sending PADI
00:35:47, 16 Jun. PPP: Sending PADI
00:35:42, 16 Jun. PPP: Sending PADI
00:35:37, 16 Jun. PPP: Sending PADI
00:35:32, 16 Jun. PPP: Sending PADI
00:35:27, 16 Jun. PPP: Sending PADI
00:35:22, 16 Jun. PPP: Sending PADI
00:35:17, 16 Jun. PPP: Sending PADI
00:35:12, 16 Jun. PPP: Sending PADI
00:35:07, 16 Jun. PPP: Sending PADI
00:35:02, 16 Jun. PPP: Sending PADI
00:34:57, 16 Jun. PPP: Sending PADI
00:34:52, 16 Jun. PPP: Sending PADI
00:34:47, 16 Jun. PPP: Sending PADI
00:34:42, 16 Jun. PPP: Sending PADI
00:34:37, 16 Jun. PPP: Sending PADI
00:34:32, 16 Jun. PPP: Sending PADI
00:34:27, 16 Jun. PPP: Sending PADI
00:34:22, 16 Jun. PPP: Sending PADI
00:34:17, 16 Jun. PPP: Sending PADI
00:34:12, 16 Jun. PPP: Sending PADI
00:34:07, 16 Jun. PPP: Sending PADI
00:34:02, 16 Jun. PPP: Sending PADI
00:33:57, 16 Jun. PPP: Sending PADI
00:33:52, 16 Jun. PPP: Sending PADI
00:33:47, 16 Jun. PPP: Sending PADI
00:33:42, 16 Jun. PPP: Sending PADI
00:33:37, 16 Jun. PPP: Sending PADI
00:33:32, 16 Jun. PPP: Sending PADI
00:33:27, 16 Jun. PPP: Sending PADI
00:33:22, 16 Jun. PPP: Sending PADI
00:33:17, 16 Jun. PPP: Sending PADI
00:33:12, 16 Jun. PPP: Sending PADI
00:33:07, 16 Jun. PPP: Sending PADI
00:33:02, 16 Jun. PPP: Sending PADI
00:32:57, 16 Jun. PPP: Sending PADI
00:32:52, 16 Jun. PPP: Sending PADI
00:32:47, 16 Jun. PPP: Sending PADI
00:32:42, 16 Jun. PPP: Sending PADI
00:32:37, 16 Jun. PPP: Sending PADI
00:32:32, 16 Jun. PPP: Sending PADI
00:32:27, 16 Jun. PPP: Sending PADI
00:32:22, 16 Jun. PPP: Sending PADI
00:32:17, 16 Jun. PPP: Sending PADI
00:32:12, 16 Jun. PPP: Sending PADI
00:32:07, 16 Jun. PPP: Sending PADI
00:32:02, 16 Jun. PPP: Sending PADI
00:31:57, 16 Jun. PPP: Sending PADI
00:31:52, 16 Jun. PPP: Sending PADI
00:31:47, 16 Jun. PPP: Sending PADI
00:31:42, 16 Jun. PPP: Sending PADI
00:31:37, 16 Jun. PPP: Sending PADI
00:31:32, 16 Jun. PPP: Sending PADI
00:31:29, 16 Jun. Device connected: 192.168.1.73, c0:b5:d7:03:9e:55, DESKTOP-FB92O2M, lease time is 172800 seconds
00:31:27, 16 Jun. PPP: Sending PADI
00:31:22, 16 Jun. PPP: Sending PADI
00:31:17, 16 Jun. PPP: Sending PADI
00:31:12, 16 Jun. PPP: Sending PADI
00:31:08, 16 Jun. Device connected: 192.168.1.73, c0:b5:d7:03:9e:55, DESKTOP-FB92O2M, lease time is 172800 seconds
00:31:07, 16 Jun. PPP: Sending PADI
00:31:02, 16 Jun. PPP: Sending PADI
00:30:59, 16 Jun. Device connected: 192.168.1.73, c0:b5:d7:03:9e:55, DESKTOP-FB92O2M, lease time is 172800 seconds
00:30:57, 16 Jun. PPP: Sending PADI
00:30:52, 16 Jun. PPP: Sending PADI
00:30:47, 16 Jun. PPP: Sending PADI
00:30:42, 16 Jun. PPP: Sending PADI
00:30:37, 16 Jun. PPP: Sending PADI
00:30:32, 16 Jun. PPP: Sending PADI
00:30:27, 16 Jun. PPP: Sending PADI
00:30:22, 16 Jun. PPP: Sending PADI
00:30:17, 16 Jun. PPP: Sending PADI
00:30:12, 16 Jun. PPP: Sending PADI
00:30:07, 16 Jun. PPP: Sending PADI
00:30:02, 16 Jun. PPP: Sending PADI
00:29:57, 16 Jun. PPP: Sending PADI
00:29:52, 16 Jun. PPP: Sending PADI
00:29:47, 16 Jun. PPP: Sending PADI
00:29:42, 16 Jun. PPP: Sending PADI
00:29:37, 16 Jun. PPP: Sending PADI
00:29:32, 16 Jun. PPP: Sending PADI
00:29:27, 16 Jun. PPP: Sending PADI
00:29:21, 16 Jun. PPP: Sending PADI
00:29:19, 16 Jun. Device connected: 192.168.1.226, 48:5a:b6:63:7f:c0, tv388559a712a0, lease time is 172800 seconds
00:29:16, 16 Jun. PPP: Sending PADI
00:29:11, 16 Jun. PPP: Sending PADI
00:29:06, 16 Jun. PPP: Sending PADI
00:29:01, 16 Jun. PPP: Sending PADI
00:28:56, 16 Jun. PPP: Sending PADI
00:28:51, 16 Jun. PPP: Sending PADI
00:28:46, 16 Jun. PPP: Sending PADI
00:28:41, 16 Jun. PPP: Sending PADI
00:28:36, 16 Jun. PPP: Sending PADI
00:28:31, 16 Jun. PPP: Sending PADI
00:28:26, 16 Jun. PPP: Sending PADI
00:28:21, 16 Jun. PPP: Sending PADI
00:28:16, 16 Jun. PPP: Sending PADI
00:28:16, 16 Jun. Device connected: 192.168.1.150, 2c:54:91:8a:b3:aa, XboxOne, lease time is 172800 seconds
00:28:11, 16 Jun. PPP: Sending PADI
00:28:06, 16 Jun. PPP: Sending PADI
00:28:01, 16 Jun. PPP: Sending PADI
00:27:56, 16 Jun. PPP: Sending PADI
00:27:51, 16 Jun. PPP: Sending PADI
00:27:46, 16 Jun. PPP: Sending PADI
00:27:41, 16 Jun. PPP: Sending PADI
00:27:36, 16 Jun. PPP: Sending PADI
00:27:31, 16 Jun. PPP: Sending PADI
00:27:26, 16 Jun. PPP: Sending PADI
00:27:21, 16 Jun. PPP: Sending PADI
00:27:16, 16 Jun. PPP: Sending PADI
00:27:11, 16 Jun. PPP: Sending PADI
00:27:06, 16 Jun. PPP: Sending PADI
00:27:01, 16 Jun. PPP: Sending PADI
00:26:56, 16 Jun. PPP: Sending PADI
00:26:51, 16 Jun. PPP: Sending PADI
00:26:46, 16 Jun. PPP: Sending PADI
00:26:41, 16 Jun. PPP: Sending PADI
00:16:57, 16 Jun. Device connected: 192.168.1.73, c0:b5:d7:03:9e:55, DESKTOP-FB92O2M, lease time is 172800 seconds
00:16:56, 16 Jun. PPP: Sending PADI
00:16:51, 16 Jun. PPP: Sending PADI
00:16:46, 16 Jun. PPP: Sending PADI
00:16:41, 16 Jun. PPP: Sending PADI
00:16:36, 16 Jun. PPP: Sending PADI
00:16:31, 16 Jun. PPP: Sending PADI
00:16:26, 16 Jun. PPP: Sending PADI
00:16:21, 16 Jun. PPP: Sending PADI
00:16:16, 16 Jun. PPP: Sending PADI
00:16:11, 16 Jun. PPP: Sending PADI
00:16:06, 16 Jun. PPP: Sending PADI
00:16:01, 16 Jun. PPP: Sending PADI
00:15:56, 16 Jun. PPP: Sending PADI
00:15:51, 16 Jun. PPP: Sending PADI
00:15:46, 16 Jun. PPP: Sending PADI
00:15:40, 16 Jun. PPP: Sending PADI
00:15:35, 16 Jun. PPP: Sending PADI
00:15:30, 16 Jun. PPP: Sending PADI
00:15:25, 16 Jun. PPP: Sending PADI
00:15:20, 16 Jun. PPP: Sending PADI
00:15:15, 16 Jun. PPP: Sending PADI
00:15:10, 16 Jun. PPP: Sending PADI
00:15:05, 16 Jun. PPP: Sending PADI
00:15:00, 16 Jun. PPP: Sending PADI
00:14:55, 16 Jun. PPP: Sending PADI
00:14:50, 16 Jun. PPP: Sending PADI
00:14:45, 16 Jun. PPP: Sending PADI
00:14:40, 16 Jun. PPP: Sending PADI
00:14:35, 16 Jun. PPP: Sending PADI
00:14:30, 16 Jun. PPP: Sending PADI
00:14:25, 16 Jun. PPP: Sending PADI
00:14:20, 16 Jun. PPP: Sending PADI
00:14:15, 16 Jun. PPP: Sending PADI
00:14:10, 16 Jun. PPP: Sending PADI
00:14:05, 16 Jun. PPP: Sending PADI
00:14:00, 16 Jun. PPP: Sending PADI
00:13:55, 16 Jun. PPP: Sending PADI
00:13:50, 16 Jun. PPP: Sending PADI
00:13:45, 16 Jun. PPP: Sending PADI
00:13:40, 16 Jun. PPP: Sending PADI
00:13:35, 16 Jun. PPP: Sending PADI
00:13:30, 16 Jun. PPP: Sending PADI
00:13:25, 16 Jun. PPP: Sending PADI
00:13:20, 16 Jun. PPP: Sending PADI
00:13:15, 16 Jun. PPP: Sending PADI
00:13:10, 16 Jun. PPP: Sending PADI
00:13:10, 16 Jun. Device connected: 192.168.1.73, c0:b5:d7:03:9e:55, DESKTOP-FB92O2M, lease time is 172800 seconds
00:13:05, 16 Jun. PPP: Sending PADI
00:13:00, 16 Jun. PPP: Sending PADI
00:12:55, 16 Jun. PPP: Sending PADI
00:12:50, 16 Jun. PPP: Sending PADI
00:12:45, 16 Jun. PPP: Sending PADI
00:12:40, 16 Jun. PPP: Sending PADI
00:12:35, 16 Jun. PPP: Sending PADI
00:12:30, 16 Jun. PPP: Sending PADI
00:12:25, 16 Jun. PPP: Sending PADI
00:12:20, 16 Jun. PPP: Sending PADI
00:12:15, 16 Jun. PPP: Sending PADI
00:12:11, 16 Jun. Device connected: 192.168.1.73, c0:b5:d7:03:9e:55, DESKTOP-FB92O2M, lease time is 172800 seconds
00:12:10, 16 Jun. PPP: Sending PADI
00:12:05, 16 Jun. PPP: Sending PADI
00:12:00, 16 Jun. PPP: Sending PADI
00:11:55, 16 Jun. PPP: Sending PADI
00:11:50, 16 Jun. PPP: Sending PADI
00:11:45, 16 Jun. PPP: Sending PADI
00:11:40, 16 Jun. PPP: Sending PADI
00:11:35, 16 Jun. PPP: Sending PADI
00:11:30, 16 Jun. PPP: Sending PADI
00:11:27, 16 Jun. Device connected: 192.168.1.180, 34:d2:70:3f:10:ea, amazon-bccc42dd2, lease time is 172800 seconds
00:11:25, 16 Jun. PPP: Sending PADI
00:11:20, 16 Jun. PPP: Sending PADI
00:11:16, 16 Jun. Device connected: 192.168.1.127, 48:2c:a0:6e:22:7a, Unknown Device, lease time is 172800 seconds
00:11:15, 16 Jun. PPP: Sending PADI
00:11:15, 16 Jun. Device connected: 192.168.1.216, e4:84:d3:2d:c9:40, Unknown Device, lease time is 172800 seconds
00:11:10, 16 Jun. PPP: Sending PADI
00:11:05, 16 Jun. PPP: Sending PADI
00:11:00, 16 Jun. PPP: Sending PADI
00:10:55, 16 Jun. PPP: Sending PADI
00:10:50, 16 Jun. PPP: Sending PADI
00:10:45, 16 Jun. PPP: Sending PADI
00:10:40, 16 Jun. PPP: Sending PADI
00:10:36, 16 Jun. Device connected: 192.168.1.118, c4:65:16:63:c6:6f, HP63C66F, lease time is 172800 seconds
00:10:35, 16 Jun. PPP: Sending PADI
00:10:30, 16 Jun. PPP: Sending PADI
00:10:25, 16 Jun. PPP: Sending PADI
00:10:20, 16 Jun. PPP: Sending PADI
00:10:17, 16 Jun. Device connected: 192.168.1.4, b4:86:55:ea:fa:4d, Honor_10-cd254d6f62e685de, lease time is 172800 seconds
00:10:15, 16 Jun. PPP: Sending PADI
00:10:12, 16 Jun. Device connected: 192.168.1.17, 5c:96:66:6a:83:8d, Unknown Device, lease time is 172800 seconds
00:10:10, 16 Jun. PPP: Sending PADI
00:10:05, 16 Jun. PPP: Sending PADI
00:10:00, 16 Jun. PPP: Sending PADI
00:10:00, 16 Jun. PPP: Starting PPP daemon
00:09:57, 16 Jun. WAN link up (FIBRE)
00:09:52, 16 Jun. System up, firmware version: v0.06.00.0001-OT (Tue May 19 15:34:07 2020)
00:09:11, 16 Jun. System start
Leanne_T
Hi @Boring25
Leanne,
Sorry, @Boring25 , I'm not interested nor asked for the event logs which just confirm your observations, but the 3 reports & other Qs I did asked for. There is more to router stats than raw speeds.
you asked for a speed test in the first response yet now you're saying there is more to it than raw speeds. Why ask then?
Got it sorted through EE, thanks for trying.
Leanne_T
Thanks for letting us know this is now sorted for you @Boring25
I requested far more than a speedtest which is only a small part of the diagnostics needed to investigate your issues but you failed to follow it up.
Suziehall46
Same here-ever since thwe BT-EE merger. Broadband drops out intermittently-day or night. New hub and several engineer visits, but problem persists (for neighbours too!). How do I go about getting a refund for payments made for an unreliable service upon which I depend (as someone who is disabled?)
