Wifi question please
Golden291
Ive only just joined EE and when i go to settings i have two options for EE Internet, can anyone explain what they are about, and should i be using the wifi at home?
When i was  with VM i just had the one🤔 im worried that im getting  charged by  using the main one?
Here's a picture of what comes up.
Thanks for any help.
@Golden291  The second one is a EE hotspot not your router WiFi connection.  The one you are connected to is your routers WiFi connection
Thank you
The 1st 1, EE-65QFGH, you see is WiFi network of your own BB router. The others are WiFi networks you can see from your location incl. the 2nd, the public EE WiFi network.
