Wifi dropping out.
GazNH
For the past month or so the WIFI on my SH31B drops signal strength suddenly. Happens every day sometimes twice during the day. This is causing all sorts of issues with smart home and car charger going off line.
Firmware version : r4.26.1-R-1860948-PROD-83002
When I reset the router it comes back with a high signal only to drop again later that day.
11 REPLIES 11
Jim, the TP link has a customer firmware, it is connected to the EE as a wired device and is just a WIFI hot spot. WIFI on the EE is disabled. It is from a batch we used in work to add WIFI to warehouses.
My matter and ESP_Home devices are on a separate network where I have a master controller with 1 gateway device if I need to connect it to the interweb, otherwise it all runs inhouse.
G
@GazNH Got it, with you now!
