Sh40j ac adapter plug
Bob1100
I have a EE router pro WiFi 7 (SH40J) and a BT supplied (I am with BT not EE only use the EE router as it's faster)   lead acid backup battery. This backup battery power outlet cable fitted the BT Smart Hub 2 not the EE SH40J. I need a DC end plug adapter from BT SH 2 to SH40 (SH40 uses type G I believe). Can someone tell me what AC adapter end plug to get please?
6 REPLIES 6
Maestro
Maestro
@Bob1100 What BBU unit are you using? Does appear to have a type G but not right angled.
ee-smart-hub-7-pro-user-guide.pdf
Universal DC Power Adapter Tips Kit, KUOQIY 39 PCS 5.5 X 2.1mm DC Barrel Jack Adapter, with 2 PCS Ca...
Battery Back Up Plus (Digital Voice) White | EE but do check with EE that it full supports the cable type for you 7 Pro hub.
Maestro
Maestro
@Bob1100 Looks like this is the cable that is required will also depend on what BBU it fits. Seems to be out off stock but you may just have to call about it!
Battery Back Up Plus Connector Cable for Smart Hub 4 Black | EE
The BBU is Cyberpower DTB24U12B output 24W 12VDC. It doesn't say what end pin type it is using
@Bob1100 You have one of the old ones then, they only made the combined cable's that were still separate single connection for version DTB24U12V-BT3 onwards and that covered the BT Smarthub 2 and upto the EE Smarthub 6 Plus versions, one unit for the ONT and the other for the Hub.... The newer that BT/EE have is the multi plug connection, one unit fit's all with different cables for different connections, without seeing what the new BBU connection output cable is but for the old one it sure is the 5.5mm barrel connection 12V center positive same connection end fits both the BT/BBU. Got two off them on the sister's units EE supplied due to vulnerable status. ONT and EE Smarthub 6+ version SH32B....
Is there an end plug adapter (e.g. type X to Type G) adapter I can get so I can use my existing BBU?
Maestro
Maestro
@Bob1100 Not that i am aware off, links above show the tips i found, know nothing about the power connection to that Pro hub you have, EE/BT have covered it with the newer BBU unit so it would seem. The common connection type is the 5.5/2.1mm barrel, unplug your connection and see if the plug you have with BBU and BT Smarthub 2 fits both ways in both devices.
