Wifi controls
Byrnec5
I need to change my wifi setting but the app says it having some repairs, can i get access any other way?
Maestro
Maestro
@Byrnec5 Depending on the router and also what you need to change, you can log into the hub manager with a web browser try 192.168.1.254 and go from there.
