07-10-2022 05:30 PM
Hi everyone,
There are a few smartphones/ tablets/ laptops in my house. The laptops connect to the ee WiFi, and have no issues as long as they're on the same floor as the router (router is on ground floor). For the Tablets and smartphones (all Android), the WiFi constantly keeps disconnecting, i.e. will work for some time (sometimes just 5mins, sometimes 35mins) and then randomly disconnect and then reconnect 2mins later. This also happens when I'm near the router. This also happens when the landline is not in use (i.e. the landline therefore plays no role in this issue). Interestingly this has never happened with the laptops. Please can someone advise. If you need any extra info, please reply
07-10-2022 06:07 PM
Hi @ysm1234.
Are you able to go to Settings, WiFi Preferences, then check to see if Auto Switch To Mobile Data is turned on?
This could be causing the devices to switch from WiFi to mobile data.
Jon
07-10-2022 06:41 PM - edited 07-10-2022 06:43 PM
I mainly notice it on a tablet that is WiFi only....
Also, the other devices don't seem to have the issue when connecting to other wi-fi's. if this was the issue it should be across the board that they'll be issues when connecting to any wi-fi that the other devices connect to. Correct me if this is incorrect
07-10-2022 06:53 PM
@ysm1234 Hi, which router do you have?
Depending on which one, there may be some tweaks you could try to help.
07-10-2022 09:36 PM - edited 07-10-2022 09:37 PM
2. Try both a wired & a wireless speedtest here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
07-10-2022 09:38 PM
Smart hub
07-10-2022 09:40 PM
That is incorrect! It could depend on which WiFi band your devices are connecting to.
07-10-2022 09:42 PM
For the black EE Smart Hub, but not the white EE Smart Router, try separating the wireless bands/SSIDs. On the Advanced > Wireless Settings page of the SH there is a button near the top to Separate the Bands. Turn it ON. Then the 5GHz SSID will appear starting with "5GHz-" & the 2.4 GHz SSID not starting with "5GHz-". Then connect your devices to the 2.4 GHz SSID if they can't do 5GHz.
07-10-2022 09:53 PM
https://www.thinkbroadband.com/speedtest/1665175353157231655
Thanks. I don't know if I did a wired speed test aswell, if I didn't, please let me know how to do one.
07-10-2022 09:58 PM
By connecting a device by Ethernet to the router.
The wireless speedtest, if it were that, was rather slow.
