30-04-2023 09:33 PM
I’ve got my EE router located in my living room and whenever I sit in that room I can’t get a Wi-Fi signal, it also kills my 5g signal and makes my iPhone 14 Pro Max unusable.
Wifi and 5g signal are fine when not in the living room.
Can anyone suggest a remedy to this that doesn’t include my current solution of switching off the router?
02-05-2023 07:44 AM
Hi @Hlvd
Welcome to the community.
Is it just the mobile phone that can't connect in the living room or do other devices have the same problem?
02-05-2023 08:00 AM
Hi, I’ve no access to anything else to try it out, I’ve no laptop or iPad.
02-05-2023 08:06 AM
We need to establish whether the problem is likely to be with the phone or the WiFi connection, @Hlvd
Is there anyone else that you know who could try connecting their phone or another device to your WiFi in your living room?
02-05-2023 08:46 AM
No, I’m the only one in the house.
I do have an Amazon Cube in the room connected by Ethernet cable, I’ll try it through Wi-Fi tonight and see what it does.
02-05-2023 08:55 AM
