Who can actualy record 1.6gbps on a device in their property ?
Gfaefife
So i'm a new customer full fibre installed by openreach for EE.
1.6gbps guaranteed 1.3gbps. the full ee package.
Had 12 openreach engineers attend my home max speed is 945mbps.
Tested the fibre with an exfo OTDR and the line is clear.
Smart hub 2 has in input of 2.5gbps on the only wan port ( RED)  from the PON.  ( pon is the new small 2.5gbps box)
Hope my terminology for the device is correct but you get the idea.
But can only output on the 4 yellow ethernet ports at 1gbps so you can't ever get any faster with EE equipment.
Oh i hear you say its wifi 6 max speed oy of tht has been 750mbps on an android phone.
The Openreach engineer has no way to test the speed at anything over 1gbps  he can bypass the hub and do a wireless test on his mobile through the router but not using the ee software,  that comes back as being fine but then gets a text with the result at 940mbps.....
The result is EE seem to be selling a service that with the current equipment can't give you the speeds you would expect.  so if someone out there has had a min 1.3gbps and recorded it on say OKLA speed test  i would be very interested to find out how this is possible .  I also have a 2.5gbps network card hooke to the hub with cat 8 cables so my equipment is capable.
they have offered to downgrade my service but thats not why i chose EE. i wanted the high speeds and the bandwidth.
 i'm awaiting  details of what's going to happen from EE next week. as they are looking into the issue.
26 REPLIES 26
ALC473
I consistently get 1.7gbps using my own equipment. Nothing real fancy, just an alternative Netgear RS300 router (still pricey though).
WiFi 6E speeds are very similar (around 1.6gbps) which obviously goes lower the further away you get. Slowest speed in my house on an iPhone 15 pro max is around 800mbps some distance away from the router.
timprocter
@ALC473
Exactly the same as I get using a TP-Link BE19000 Tri Band router, again expensive but zero problems or dropouts since using this router.
Check this out over WiFi.
Full Fibre Busiest Home Bundle 1.6Gb.
Adzbluenose
Smart Hub Pro- 1.6gb service - speed test done on a Galaxy S23Ultra with WiFi 6E
Did you resolve your issues?
taffies84
I'm on EE and I'm on the best package they offer which the wifi 7 package and I have the Smart Hub Pro Router, on my wifi on my iPhone I can get 1gbps over wifi yet even better I'm hardwired in my office on my iMac and I get 1.2gbps on the EE smart hub pro which does push out quite a bit, like my PS5 I get 850 - 900 just under 1 gbps my game are literally downloaded within seconds. Screenshot 2025-06-14 at 00.12.11.png
Almostafish
PortableFrank
Valued Contributor
Valued Contributor
Speed is good, when it works...my connection has been down for a week apart from when I briefly managed to run this test.
