Weak WiFi signal across the house
Johnhsenior
I've recently upgraded our EE broadband to full fibre. The WiFi speed is good near the router but one floor down in our living room it is disappointingly poor. Is there a booster that can help resolve this problem?
Northerner
Hi @Johnhsenior
Which router do you have.
@Johnhsenior  Have you or can you try relocating that router to a different location?   Is the router next to an another electrical device?   If it is that could be the issue.
Mustrum
@Johnhsenior   If you want to stick with an EE solution you could ask about Smart WiFi Plus. They do other solutions, but do check with the Broadband Care team as they are not all interchangeable, so will depend on the router you have.
Or have a look at your own router with a Mesh system.
Smart WiFi Plus
The smartest way to banish that black spot in the back room. Extend your WiFi and work or game anywhere at home.
Smart WiFi Plus extends your network to give you a single, seamless connection in even those hard-to-reach places. It works with your router, using the latest WiFi 6 tech to give you even faster WiFi speeds.
No more dropping off between rooms. Just strong, fast WiFi all round your home. Or you can get £100 back.
£10
monthly*
Increases 31 March
24 month contract
