VPN Installation
BLUEZULU
I want to install a VPN on my EE Smart  Hub Router, namely Express VPN. I can install it on certain individual devices in my network but not on the router itself. When I go into the VPN section of the router it says " Your EE Smart Hub has been designed to work with most VPN (virtual private network) software." that is all. I contacted EE and they said they couldn't help.
6 REPLIES 6
bobpullen
Star Contributor
Star Contributor
EE's routers cannot be configured as VPN clients.
@BLUEZULU   You install VPN clients on the devices using the access point ie your router.  You can not install VPNs on the router.
Thanks, I thought as much, saves me any further searching
Thanks Chris, apparently a VPN can be installed on a router to cover all the connected devices but just not on a EE router
@BLUEZULU   You got an answer for the question asked.
Mustrum
@BLUEZULU  Express VPN have a list of routers that work with their VPN in this website.
https://www.expressvpn.com/vpn-download/vpn-router?srsltid=AfmBOorGimol88DYUr_Y03lxcKZfJ5Kx4ykzMG729...
Setting up a 3rd party router on EE is available here https://ee.co.uk/help/broadband/getting-started/using-and-configuring-a-third-party-router
