Ubiquity Router for VPN
Matthew109
Hi all.  I have just moved from a Virgin Media connection to full fibre EE.  I had my virgin router set to modem mode so I could use my own router which has VPN's set up to other sites.  I can't find how to turn the EE Smart router to the same, any suggestions?  Many thanks 🙂
18 REPLIES 18
No, I said the pwd is HQNPASS123456.
Hi, thanks for that. I tried that first and thought maybe I had misread it. It must be the router settings that are incorrect. Thanks for your help
pip11
Scholarly Contributor
No, your password will be HQNPASS123456. with the numbers replaced with those found in your user neame.
Matthew109
Oh right! Ok I misunderstood I didn’t realise it was HQNPASS………..
I’ll try that again, thank you 🙏
Still doesn’t work!
Have you read the BB Username exactly from the EE router?
Matthew109
Yes, copied and pasted
@Matthew109 - I assume you probably have this covered as you're talking about usernames/passwords, but just in case - has the Ubiquity router been re-configured to use PPPoE? I believe a Virgin cable connection will use DHCP for the WAN connectivity which differs significantly to how things need configuring on EE.
Ian06
Have you tried following the instructions here: https://ee.co.uk/help/help-new/broadband-and-landline/home-broadband/how-do-i-use-my-own-router-for-...
As XRaySpecx said the ONT is the modem and connects to your router via an cat5e ethernet cable. The router connects via it's WAN port using PPPOE.  The user id and password can be found in the EE router (which downloads them on making the first connection.)  Failing that contact EE support who can advise the userid and password as per the above link.
