07-02-2023 09:30 AM
My EE broadband speed keeps dropping buy almost 250%. The only reason is even know it's happened is because I go to download something and the download speed is very low. I then have to restart my router and usually it returns to normal until it drops again. After restarting the router usually shows this error message and then connects anyway?
07-02-2023 10:33 AM
@Ludox Alas it is very unlikely to get better on it's own!
If you can, then remove the faceplate on your master socket and connect the router via a dangly filter to the test socket and see if that improves things.
Otherwise report the problem, sooner rather than later.
07-02-2023 09:44 AM
@Ludox they are very inconsistent results, have you checked your phone line for noise? Dial 17070 ideally from a corded phone.
Do you get the same problems with your EE Router?
Have you reported a fault to the Broadband Care Team?
07-02-2023 10:00 AM
I don't have a phone sadly I can't test it. Also it's broadband only so not sure if it would work in that case anyway? And no I haven't reported it yet. God knows where that router is lol.
07-02-2023 10:33 AM
07-02-2023 10:42 AM
Yeah I have contacted the care team so go an Engineer coming out on Friday (fingers crossed) so hopefully they can make sense of it all. Thank you for your time.
