USB Printer Sharing
pds24
Hi. I have just signed up with EE. I have an HP Color LaserJet printer connected to my Smart Hub 3A. I wish to print from my desktop computer connected to the Hub via WiFi. How do I turn on USB Printing Sharing on my Hub?
6 REPLIES 6
@pds24  Why not just connect the printer to the WiFi ?
  What model HP laser jet is it ?
The printer is getting a little old, but still works well, but doesn't support Wi-Fi printing. The model is the HP Color LaserJet CP1515n.
Mustrum
@pds24   there is no facility on the newer EE Hubs to use the USB port for anything, other than charging.
That said Smart Hub 3A is not something from the list of EE Hubs, do you mean the Smart Hub plus?
https://ee.co.uk/help/broadband/getting-started/set-up-guide
@pds24 : I do not recognise a "Smart Hub 3A". Is it an EE or BT router? Which router do you have (read label or post a pix)?
@pds24 Does also say that model is network ready and has an ethernet port on it, worth a look to see if so.
hevster_uk
Just discovered the Smart Hub Plus USB port has no usable function.  Same as you I wanted to use the port for a usb attached printer, or for file sharing. Could do both with my previous BT Hub but cannot with the new EE hub.  Downgrade in functionality and I’d advise anyone who needs this  and is considering moving from BT to EE to think hard about it. I’m now having to invest in extra kit to get the functionality I had previously…
