Third party router problem
JRS15
Having wrestles with the EE provided router for months I’ve decided to connect a third party router.
I have a TP-link AX5400 (Archer73) and i’m connecting it to the Nokia ONT-010-G-T that came with the EE router. I’m connecting my WAN port on the TP-Link (coloured blue) to the yellow 2.4Ghz port on the ONT modem.
I’ve set the TP-Link to PPOE and put in my details name@emailaddress.com. I’ve tried both adding the password and leaving it blank, neither connects.
Is there something I am missing? Is this set up viable or do I need a different modem or ??
26 REPLIES 26
Yes I can see those options through both the Tether app and connecting using the http://192.168.0.1 methods. The latter doesn’t have any other selections unless i choose IPv6, then it gets overly complicated.
I’m using my username and login details copied directly from the EE hub (which does connect) but the TP link just won’t.
I asked EE for login details and they sent me the same info you shared. I even tried the verbatim btinternet as printed, obv no joy
I’m stumped
Sent from my iPhone
ok i’ll try that
Sent from my iPhone
Mustrum
@JRS15  alas I can't see what you are doing wrong, but suspect it is something simple.
Are you  trying to set it up as a router or AP?
What EE Broadband service do you have?
Do you have digital voice or TV?
Community Hero
Community Hero
@JRS15 What model of EE Router do you currently have?
I have EE broadband fibre to the property. No voice and no TV. TV is sky connected via ethernet.
I have the 700mbps pkg.
Sent from my iPhone
Sent from my iPhone
Community Hero
Community Hero
@JRS15 Empty post apart from Sent from my iPhone? You do know that you set up router admin with a user/password and this is only to get to the router, then once you set up the PPPoE you have a separate user/password this is were you set the EE defined parameters.
Hi Jim,
Its the Smart Hub Plus.
Community Hero
Community Hero
@JRS15 Then follow the guidance that @Mustrum @XRaySpeX have advised, if you have the Tp-Link router all messed up then factory reset it, use a laptop/pc to web setup the router, if you want to use the app, go slow and be careful, it normally does a good job of getting it right.
Solved.
Username and factory reset
Thank you folks. Respect 🫡
Regards,
Jim
