TP Link BE900 / BE24000 IPv6 settings
AHarMan2
Just a quick question,
Anyone with this router able to screenshot their IPv6 settings please ?
Cheers.
iJason
Valued Contributor
Valued Contributor
AHarMan2
That KB article works fine and certainly gets me up and running, but IPV6 is still not working and im not sure how to configure it in the router. IPV4 is fine however.
Someone did i thought post info on how to set it up for the BE900 but I cant find it now.
@AHarMan2 You will probably struggle for specific's of that particular router, the OP post may give some idea's. Once you have it set and working, you could post your setup, do check speed's before setting incase the ipv6 causes slowdowns.
Solved: IPv6 - EE Full Fibre (Same as BT?) - Page 3 - The EE Community
