IPv6 - EE Full Fibre (Same as BT?)
ShutterbugLozza
Hello everyone,
As someone who works in IT, I thought it might be worth learning about IPv6 and as a starting point, I've been considering implementing it on my home network. I'm currently utilising a Ubiquiti USG 3 and have it connected to EE Full Fibre. It's configured with IPv4 on the WAN port, using the EE standard username and password, which works perfectly.
My question is whether or not EE has implemented IPv6 on the FTTP / Full Fibre network and what the appropriate details are? The USG 3 requires the following settings:
I've read some alternating information on this in different places, some suggest that EE has no IPv6, some say only on the Mobile Network and others where it uses the same connection settings as BT Full Fibre - which I've tested (DHCPv6 and /56 as the Prefix delegation size) to no avail. Wondering if there's any EE specialists who might have some insight on this?
Thanks in advance!
29 REPLIES 29
I'm using an edgerouter 4. Are you?
This is a good place to start: https://grh.am/2018/ipv6-with-bt-infinity-and-an-edgerouter-x/
ralphrmartin
I'm using /56, and it works for me.
I'm using a TP Link ER707-m2 router; is Edgerouter 4 a Ubiqiti product?
Anyway...I need to either delete or update my previous post as I have since made changes and now get a 10/10 on Test your IPv6. (test-ipv6.com)
ER707-m2 (via OC200 controller) settings for EE FTTP IPv6
WAN settingsWAN settings
LAN settingsLAN settings
ralphrmartin
Yes, it is an older Ubiquiti product.
Well done, getting it going!
I nearly went down the Ubiquiti route but I couldn't justify the cost over TP Link...Ubiquiti products look so good though.
Thanks, took a while but now it's done...I need to find something else to mess with now 🙂
Would this work on EE 5G? I am using a Huawei 5G router plugged into WAN2 of my UDM Pro.
Thank you
Yes, @Yans335 , IPv6 is provided on the mobile network. However this thread was about fixed-line BB where IPv6 wasn't introduced until the provision of EE New BB in about Sept. '23.
Yans335
Great stuff, thank you XRaySpeX, i have been after the settings I need to configure my UDM Pro to run with EE 5G (WAN port of Huawei plugs into WAN2 port of UDM Pro). I have it working on IPV4 but feel like I am missing out on speeds and want to utilise IPV6 but dont know the settings?
rill
Good morning everyone. Apologies for bringing this topic back alive.
I'm seeing mixed messages in this thread about v6 availability. I'm with BT and the end of my contract. I'm looking around for options. One option is BT's EE broadband.
I'm willing to give it a try but I'm desperate to know if I'd lose ipv6 or everything stays the same. I've asked sort of the similar question on the bt community site and those guys quite certain ipv6 is generally available for broadband customers as EE is a subdivision of BT.
I'd expect the change only be an administrative stuff, however I want to know what to expect before I sign the 12 months contract.
I use my own router if that matters. I'd prefer nothing to be changed. No new installation, no new (locked down) router, no new bridge mode on new device. Still available v6 with /56 prefix as it is now.
I'm 🤏 close to renew with bt (ee) offer on the my bt page just let this clarify first.
Thanks in advance. Have a wonderful long weekend all
No need to change anything. It just carries on like before (at least, it did when I changed over just over a year ago, and no changes have been needed since). I host an ipv6 enabled website.
