Test broadband speed
VinceM
Am trying to test broadband speed by following instructions on EE webpage which says:
  1. Open the EE app.
  2. Select Manage.
  3. Select Broadband.
  4. Select See what’s included in your plan to get a breakdown on what you’re expecting.
  5. You can select a Test speed from the Broadband page.
Trouble is, there is no "See whats included in your plan" tile or "Test speed" tile on Manage, Broadband pages on the app!
Any help much appreciated!
@ckgerard : Try a speedtest, preferably wired using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
12 REPLIES 12
VinceM
Community Hero
Community Hero
@VinceM If you are not seeing it, just click on your EE router, and test speed. What version of app do you have?
Try this speedtest instead.
Try a wired speedtest, preferably using an Ethernet cable, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
354-
Star Contributor
Star Contributor
ckgerard
The app's speed test hasn't been working for days. Why is there not one available via this website?
@ckgerard If it's only been day's why worry about it! Plenty other test's out there, follow @XRaySpeX advice.
Thuydao
Hi. I paid the bill. but I still can't call and my network is dead. Thanks
@Thuydao No idea what you are looking at need or have even posted in the correct section!
