Terrible broadband
Ian233
Moved from BT to EE
was told it would be better because we would have a direct line, but honestly it’s much worse. Signal around the house is terrible. Everything is fuzzy and takes ages to load.
Extremely disappointed
VillanII
I was moved from BT to EE in March & I am in the same boat. Internet WiFi keeps crashing, very poor customer service. I can carry on here but I need to complete my 9 complaints. They brag about being the best provider for 11 years, I shudder to think what everyone else is like. Do not use the customer call back. They do call you back after about 30 minutes but from a different department. So, you have to wait another hour to talk to somebody & still it is not fixed
Ali_A
Hi @Ian233
Welcome to the Community
Sorry to hear of the experience you're facing with the EE router.
Is it the WIFI signal you're having issue with around the house, or the actual internet connection?
You can test this by connecting a device such as a laptop directly to the router using an ethernet cable.
Ali
Which EE BB plan are you on including its speed? What EE router do you have (read its label)?
My contract is Full Works: Fibre 67 Download speed 66Mbps
AndyB
@VillanII : Welcome to EE's Home Broadband Forum.
