19-08-2022 08:38 PM - edited 19-08-2022 08:43 PM
Hi, tech noob here.
I've recently bought a set of Google Mesh Wifi to extend the coverage in my house.
I started by setting up the first Google Wifi by plugging in the Ethernet cable (into my Google Wifi) and WAN port (into my EE Smart Hub). I followed the steps in the Google Home app but when it tried to connect to Wifi, it says "Connection failed". I tried a few times but it didn't work.
I checked that the first Google Wifi I've connected is also emitting Wi-Fi (presumably because of the connection to EE Smarthub). So now I have 2 devices (Google & EE SH) emitting Wifi. However, the current setup won't let me connect to my 2nd or 3rd Google Unit because Google Home can't connect the first unit with Wifi.
What am I doing wrong here? I searched through the forum, and lots of people saying that the EE SH cannot be used as a bridge, what does it has to do with my Google unit not being able to connect to Wifi?
What should I do now if I want to make it connect to the Wifi so I can enable my 2nd and 3rd Google units? Do I need to replace my EE SH router with a different router? Please kindly recommend any product that would fix this problem.
My product is Fibre Plus Broadband.
Thanks in advance. 😃
19-08-2022 09:12 PM
@Jay239 were it me, I would send the Google back and get something that will work.
The Google system is quite old now, and also not very flexible. It is a router as is your Smart Hub which is not a good thing on the same line, As you have already found out, they clash.
You could set the Google up as a Wireless access point, but that would limit its functionality.
If you are able to send it back, you could get a router with built in mesh capability and extra hubs, or EE also do a home WiFi pack
All that said, assuming you are on VDSL, a W9970 is one of the cheapest devices that works in bridge mode I can think of, but you loose so much with your choice.
If you are spending money, think about future proofing your set up, so WiFi 6 router/mesh with 1Gbps plus WAN port - or go cheap and just get some home plug access points.
Sorry - just my thoughts.
19-08-2022 09:50 PM - edited 19-08-2022 09:52 PM
Thanks, @Mustrum, I didn't buy it, it was sent by my company because I complained to them that my WFH wifi was spotty 😅!
I can certainly return it if Amazon Business would take it back!
What product would you specifically recommend for "WiFi 6 router/mesh"? Would something like this work? It won't end up becoming like Google Wifi right?
19-08-2022 09:53 PM - edited 19-08-2022 09:54 PM
Whose WAN port? Should be EE SH LAN > Google WAN.
19-08-2022 10:02 PM
Thanks @XRaySpeX , so my current setup is:
1. BT white box (on the wall) to EE Smart Hub "Broadband"
2. EE Smart Hub WAN port (slot 4) to Google Wifi (like in the screenshot)
Am I right?
19-08-2022 10:08 PM
I don't believe so but there's something you are not telling us.
On the Home > Advanced Settings > Broadband > Internet page of the SH what is WAN Port set to?
19-08-2022 10:12 PM - edited 19-08-2022 10:13 PM
Thanks @XRaySpeX , WAN Port in the "Internet Page" is set to Off. Should I switch that on?
19-08-2022 10:20 PM - edited 19-08-2022 10:24 PM
No, it should stay OFF. It's only ON when the SH is connected to a separate modem which you don't have. Here the SH's WAN is the DSL to the phone socket.
With it OFF Port 4 of the SH is not a WAN but a LAN port. That is correct.
The Q remains what port is the Google using? It should be a WAN port. I don't know those symbols the Google has on it. What does its instructions say?
EDIT: Maybe that port symbol looks a World which would imply it is a WAN. If so, that would be correct!
19-08-2022 10:23 PM
Thanks @XRaySpeX, So I checked for Google, it's definitely a WAN port that I'm using.
So it's LAN from EE SH, and WAN from Google.
Perhaps like one of the users replied above, I need a different router to replace the EE SH, otherwise, it won't work. =(
19-08-2022 10:30 PM
Slightly! It's LAN from EE SH, and WAN to Google.
As it is it should work.
