Steps to Setup Google Mesh System (Help!)
Jay239
Hi, tech noob here.
I've recently bought a set of Google Mesh Wifi to extend the coverage in my house.
I started by setting up the first Google Wifi by plugging in the Ethernet cable (into my Google Wifi) and WAN port (into my EE Smart Hub). I followed the steps in the Google Home app but when it tried to connect to Wifi, it says "Connection failed". I tried a few times but it didn't work.
I checked that the first Google Wifi I've connected is also emitting Wi-Fi (presumably because of the connection to EE Smarthub). So now I have 2 devices (Google & EE SH) emitting Wifi. However, the current setup won't let me connect to my 2nd or 3rd Google Unit because Google Home can't connect the first unit with Wifi.
What am I doing wrong here? I searched through the forum, and lots of people saying that the EE SH cannot be used as a bridge, what does it has to do with my Google unit not being able to connect to Wifi?
What should I do now if I want to make it connect to the Wifi so I can enable my 2nd and 3rd Google units? Do I need to replace my EE SH router with a different router? Please kindly recommend any product that would fix this problem.
My product is Fibre Plus Broadband.
Thanks in advance. 😃
19 REPLIES 19
Mustrum
@Jay239  sorry, been away, but did not forget you.
One other question, are you on full fibre, or G Fast - is your router plugged into a telephone socket, or an OpenReach ONT / white box with lights on it?
Depending on the answer, your previous link looks very interesting, but i would need to look at the specs in more detail.
PS just spotted another reply to this thread,  whilst it should work, you will still get the double NAT issue.
@Mustrum : OP is on Fibre Plus plugged into BT phone socket.
Jay239
Hey @Mustrum and @XRaySpeX , yes it works, I do get Wifi emitted from my Google Wifi. Except now I have both Google and EE emitting Wifi 😂
And yes, it's LAN from EE, WAN to Google. Gosh I thought things should be easy!
What's wrong with that? At least you'll know which router your devices are connecting to. If you like you could either:
  1. Disable the WiFi on the SH. Then all WiFi devices will connect to the Google.
  2. Rename the SSIDs (& pwds) of the Google to be those of the SH or v.v.
Mustrum
Hey @Jay239  after going round some houses, we are back at my first answer, but although @XRaySpeX  says you are plugged into your telephone line, not sure what speeds your line is capable of. If you could show the results of your phone number in the BTW DSL checker to make sure we recommend the right modem.
 https://www.broadbandchecker.btwholesale.com/#/ADS
@XRaySpeX  we seem to be back to step one!
No, @Mustrum , you seem to have introduced a 2nd Q on top of what the OP asks:
  1. The OP possesses certain kit. Should it work on his current EE BB? If not, what should he get instead?
  2. The OP possesses certain kit. Is it the best/right kit to use his current EE BB? If not, what should he get instead?
I'm only interested in 1.
Mustrum
@XRaySpeX  errm, in the first post the OP got one Google device working, not any of the others, Nothing has changed.
So yes, of course I have added more as we added nothing other than my suggestion of starting again, looking at the requirements, and coming up with a solution that provides a solution that meets the needs of the OP.
Have you never got some set-up wrong 1st time? So it's not completely working. So let's try & find out why as it would seem that it should work rather than give up & tell OP to go out & buy something else. So far I have spent all the time checking that the initial config was correct for the 1st node as the OP's description of it was incorrect or at least unclear.
So, @Jay239 , to move on, what is not now working?
  1. Are you able to connect devices OK to the 1st node?
  2. Are you still unable to connect the other nodes?
  3. Have you tried my suggestions of disabling WiFi on the SH, etc?
Thanks both, to answer your questions @XRaySpeX :
    - I have 3 Mesh point, the first one is emitting Wifi because of the LAN-WAN connection, but from the Google App it says it's not connected to the internet. So I cannot proceed with connecting all the 3 Mesh points.
    - The first nodes emits Wi-Fi but the app says otherwise. So I can't proceed setting the second one.
    - Yes I did, Google app still says "Connection Failed".
Sounds like a Google App thing now. I will consult them. Thanks y'all!
Can't it be done w/out the Goggle app? It's only a matter of connecting devices, like a phone, to a router. Just connect them & see if they can see the Net & get a service.
