10-05-2024 05:45 PM
Hello how can I check the broadband speed on the app as I don't think I'm getting close to the speed guarantee
10-05-2024 05:48 PM
Use a speedtest e.g. http://www.thinkbroadband.com/speedtest.html .
11-05-2024 02:48 PM
Just about getting half the guaranteed speed we had openreach up they have suggested moving to another BB provider
11-05-2024 03:28 PM
@Eugenedonaghy Hope your not doing speed check on a mobile device over a wireless wi-fi connection, to many variables for error... Best to check on an ethernet connection to router, with all wi-fi devices off if possible.... What is your minimum speed, and when OR engineer tested the line, did he tell you what he was getting....
11-05-2024 04:29 PM
Guaranteed speed is 13Mps copper connection to property from pole. Engineer didn't tell us speed when he was up
11-05-2024 06:05 PM
@Eugenedonaghy Are you on a fairly slow broadband package at those kind of speed's. did the OR engineer not find any faults when he tested your line. If you log into your router, what is the current sync speed that it is showing. When he suggested moving? are there new other broadband suppliers currently available it's an unusual request from an OR engineer.
11-05-2024 06:07 PM - edited 11-05-2024 06:08 PM
11-06-2025 03:00 PM
What is considered as guaranteed speed? To me it should be the minimum you get all the time whereas we are merely getting our guaranteed 19mbps very rarely and EE/Openreach don’t seem to care just keep suggesting endless resets, moving the router etc etc which needless to say none of this works and hasn’t for the last year or more - at our current whits end with them tbh
11-06-2025 03:13 PM
@Discoverylimb : Your Guaranteed Speed is the speed at which if you consistently fall below. EE will investigate & attempt to get it back above. If they are unable to, you are free to leave your contract FoC.
See Speed Guarantee
11-06-2025 03:16 PM
@Discoverylimb : Welcome to EE's Home Broadband Forum.
2. Try a speedtest, preferably wired using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
