on 30-01-2024 07:03 PM
Recently swapped from BT hub to EE hub. Everything connected expect one PC. Tried everything, The line has been checked out, PC checked out and finally EE engineer came to the house and check hub and PC . Never come across it before. PC recognises the hub but blocks the connection via Ethernet and WiFi.
Switch back to BT hub and connects straight away. EE 2nd hub sent and same issues.Hours wasted ! Any ideas? Thanks
on 31-01-2024 08:56 AM
Does sound strange. Could your virus software be blocking the connection for some reason? If you have the option to test, temporarily disable/quit your virus protection software to rule that out.
on 01-02-2024 08:11 AM - last edited on 01-02-2024 08:13 AM by Leanne_T
Tried a lot of things. Hours wasted and still who knows?
Will keep to the BT router !
Re- install Ethernet driver and still no internet. The hub sees it .
All the best
Darren
[mod edit: personal details removed from the forum]
