Smart WIFI PLUS LIGHT IS TOO BRIGHT!
GR54ANR
Hi! Is there a way to dim/put off the light on the WiFi plus as it is in my bedroom and disturbs my sleep.  Thanks!
Ewan15
Expert Contributor
Expert Contributor
@GR54ANR Welcome to the forum.
I n the EE App Select Manage Broadband->Broadband
Click on the link below the image of your router
Select the three dots at the Top Right of the Screen
There you will find the option Change hub light brightness, which will allow you to dim it or switch it off
Hope this helps
Schockwave
Hello @GR54ANR ,
Welcome to the community,
You can either stick something over it, or put a cloth over it, whilst asleep and then take the cloth off once awake, I do this for a monitor I have.
Ewan15
Expert Contributor
Expert Contributor
Hope this helps
Thank you sooooo much! I have managed to do it, and would recommend dimming or switching the light off rather than covering it up because it gets quite hot. Hopefully my other respondent will see your instructions and do it too. Thanks again.
Sent from my iPhone
Hi Schockwave! Thanks for responding. Covering it up has been my solution, but I was concerned that it was getting quite hot. Did you see the other reply I received? I have been able to switch the light off altogether in the bedroom and dimmed the other two. Sorted!!
Sent from my iPhone
@GR54ANR , yes , I saw that, which is good, you are able to switch the light to off or dim it, thank you.
