Smart Hub SH32B and printer
Jandy54
I’m having trouble finding a laser printer that will work with 5G. I have the Smart Hub SH32B, is this dual band? I don’t understand much about the technical stuff, but someone told me that all I need do is enter 2.5ghz (?) when setting up a printerThank you.
The EE SH+ (SH32B) is dual band, 2.4 & 5 GHz. Under Advanced > Wireless Settings try setting up the Compatible WiFi SSID to connect your printer to.
bobpullen
Star Contributor
Star Contributor
@Jandy54  - I'm unsure if you're asking about a laser printer that will work with an SH32B, or if you already have a laser printer and are struggling to get it connected to your SH32B?
If the former, then I have one of these Brother printers that seems to work OK.
Thank you for helping, much appreciated.
